Thread: voyager swmpro filter
    i have an voyager swimpro filter system, and have taken the top off to clean filter, but now when I put the top on it wont screw all the way it leaks around the sides,, I have taken to local pool place it is missing the two locking clips but they have always been gone,,, it doesnt seem to be screwing all the way like something is holding it,,, help pool is draingin
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    Re: voyager swmpro filter
    Welcome to TFP!
    My first thought is that the o-ring where the two halves meet may not be seated correctly. That would prevent it from closing up.
    22,553
    Did you lube the o-ring good with pool lube before you reassembled it? That will probably help if you didn't.
