Page 1 of 3 123 LastLast
Results 1 to 20 of 57
Thread: Taylor K-2006 kit
    Taylor K-2006 kit
    Mine finally came today and boy, it's complicated. Now for the FC do I aim for0.2ppm or 0/5ppm. There are different instructions depending on which I use.
    15 x 30 oval above ground, 13000 gals, 1 HP pump, sand filter.
    Re: Taylor K-2006 kit
    Should I test my CYA before the FC test? anyone got a BC for my headache....
    For swimming pools it is best to do the FAS-DPD test by 0.5s, which gives you all of the precision you need.
    Do the chlorine test first, PH second, and after that the order does not matter.
    Thank you!!!!!!!!!!!!
    OK, first test and vial did not even turn pink, so I need chlorine...should I just go on and add the bleach or do all the tests first.
    22,468
    It probably doesn't matter but Id' go ahead test the pH and then add the chlorine. You can adjust the pH at the same time if you need to.
    37,415
    What does your water look like?
    Do a full set of sets since the pH may need adjusted first if you require a high level of FC for the shocking process.
    We had the solar cover on it last week and when we removed it, it was green. So we vacuumed and shocked it. Now it's no algae, but a little cloudy.
    37,415
    Did you follow the Shocking Your Pool process?
    Sounds like you will need to do that again and verify you pass the 3 tests to stop shocking.
    That said, post up a FULL set of results so we can see what should be adjusted before you start.
    No I used Shock It...Didn't know about this. So you're saying that I can use the liquid chlorine to shock the pool also? What reading am I looking for as a shock value?
    Check the pool school button on the top right, your shock value depends on what your CYA level is.
    After you test CYA, check the CYA/Chlorine chart. Shocking is a process and the FC shock level is listed on the chart, shocking can be done with any form of chlorine. Most prefer liquid. Adding chlorine daily is considered maintenance (even though the products are most often labeled shock).
    It will take some time to get accustomed to the test kit, but after you get some experience using it and spend time reading here your pool will be very simple to take care of!
    Aaron
    [ Vogue Vectra 24' AG | Hard plumb: Hayward Power-Flo Matrix 1HP 2-speed, 27" sand filter & Pentair MiniMax 100 NG | Taylor K-2006 | Central IL ]
    Powered by: TFP, PoolMath & TFTestkits
    OK, trying again this morning. Question: it says to multiply drops in step 3 by equivalence in step 1. Step 1 says: for 1 drop = 0.5ppm, use 10 ml. sample. So what am I suppose to multiply the drops I count by? 0.5?
    37,415
    Yes. Each drop is 0.5 ppm with the 10 ml water sample.
    Posted with Tapatalk ... sorry if I sound short ... hate typing on phone
    22,468
    Yes, if you're using the 10ml sample you multiply the number of drops by .5.
    The reason they word it the way they do is because you can either use a 10 ml or a 25 ml sample. Just disregard the 25 ml sample and always use the 10 ml sample and multiply the drops by .5.
    OK, so here's what I have:FC 0.10 CC 0.10 PH 70 I had to add 5 drops to the base test Alkalinity 30 Calcium 60 ppm CYA 49 ppm. Suggestion?
    37,415
    If each drop is 0.5ppm ... how are you reporting 0.10ppm which would be 1/5 of a drop? I think you have a decimal place error.
    it took 2 drops
    37,415
    2*0.5 = 1.0ppm
    Which is way too low. Look at the Chlorine CYA Chart. Your absolute minimum should be 4.0ppm (8 drops).
    How does the water look? If the FC is that low and apparently the CC is also 1ppm ... you probably need to go through the Shocking Your Pool process.
    OK, I'll do that. Thank you for your patience!
  20. Back To Top    #20
    Should I retest the FC tonight? I mean I know it will be high, so should I bother?
