Thread: K2005 vs K2006
    kkpjm's Avatar
    May 2011
    Quakertown PA
    41
    K2005 vs K2006
    So the inlaws gave me a kit as a gift. It's a Taylor K2005. As far as I can tell, the biggest thing is that is not the FAS-DPD test method for chlorine. I've been using it for a while and seems to be giving good, consistent results. Is there any reason to consider upgrading to the 2006?
    20x44x8 Cardinal vinyl IGP, 33000 gal, 2 hp Mustang, 60 SF CrystalWater DE, Zodiac LM3 SWG
    Mod Squad JohnT's Avatar
    SW Indiana
    9,198
    Re: K2005 vs K2006
    So you can measure your chlorine while at shock level. You can order just the FAS/DPD test kit from TFTestkits.net and you'll be set.
    kkpjm's Avatar
    May 2011
    Quakertown PA
    41
    Re: K2005 vs K2006
    That was the only reason I came up with, too....thanks!
