Thread: Opening Pool, filter drain plug wont go back in?
    Hey guys,
    I am just trying to get my pool open and clear the water up but when I go to screw in my filter's drain plug it doesn't catch the threads to screw in. It's like the threads are gone on the inside of the filter and upon visual inspection there is what looks like rust in and around the drain hole. The drain plug is half threaded and half smooth so I can get the smooth part to slide up inside until the threaded part and I can sit there and attempt to screw it all day and it doesn't go in.
    Has anyone else ever had this problem? I am thinking that I might have to find an all smooth plug and somehow seal the hole with some kind of plumbers paste so it doesn't leak.
    If anyone can help me out with suggestions that would be great, Thanks!
    12,500 Gallon Fiberglas spool
    Hayward S210 Sand filter
    Hayward Superpump
    Tulsa OK
    been using BBB since April 2008
    Guess What?????
    BEEN ALGAE FREE SINCE APRIL 2008
    30,431
    Brand, type and model of filter?
    It is a SwimQuip sand filter, not sure of the model (label ripped on filter), but its about 4 feet high and a couple feet in diameter, and I would guess it's at least 5-10 years old.
    Thanks again.
    Hayward Superpump
    Tulsa OK
    Guess What?????
    I had that happen to me on my heater. I had to retap the threads to get it to work again.
    Well I just kinda banged the plug up in there and its not leaking anymore so we'll see how it holds up. Retapping the hole would be my next option though.
    Thanks for the help!
    Hayward Superpump
    Tulsa OK
    Guess What?????
