Thread: pump for large above ground
    Jun 2012
    Greensboro NC
    19
    Hi all
    New here and have been reading a lot. Just ordered a new 30' round above ground and was wondering if a 1hp pump would be enough. Most of the pool sizes I could find in searches were smaller, so would a 2 speed 1hp pump be sufficient as well as efficient for 20,000 gallons? I was thinking about a 24" sand filter too. Any recommendations?
    Thanks
    Robert
    30' Wilbar ABG Resin, 26" Pentair Sand Dollar sand filter, 1 hp- 2 speed Pentair Optiflo pump
    Re: pump for large above ground
    Welcome to TFP!
    Sure, a 1 HP pump will be fine, and a two speed 1 HP pump will save you money.
    Jun 2012
    Greensboro NC
    19
    I see a few above ground pools using in-ground pool pumps/filters and was wondering if there was any benefit to these. Since I am doing this from scratch,I would be willing to spend more up front on the better equipment if it saves electric/repair costs later on. My power is around 11 cents per K watt. Is the in ground equipment really better?
    Thank you
    Robert
    In-ground pumps are designed to work with long plumbing runs and tend to be inefficient when running on systems with short plumbing runs. As long as your pump is below water level and the plumbing runs are not too long (say under 20 feet) stick with an above ground pump.
    Jun 2012
    Greensboro NC
    19
    Thanks for clearing that up. I will post pics of my build as it progresses.
