Results 1 to 12 of 12
Thread: How much Borax?
    May 2012
    Allentown, PA
    219
    How much Borax?
    I have a 20,000 gallon pool and just started adding borax 20 mule to the pool to help raise ph. I do not have any borate testing strips, but was wondering how many 4lbs. 12oz boxes of borax I can add per season (June - sept.15) and still be in the acceptable range for borate? I'm sure someone knows the answer to this. Thanks for your help.
    21,500 Gallon Vinyl liner pool Eastern Pennsylvania
    Hayward 2 HP pump 2" Pvc pipes Full Sun Pool
    Hayward sand filter, Compupool CPSC 48 SWG
    12mil solar cover and reel
    Re: How much Borax?
    About 25 boxes in one season, or eight boxes every season for many years in a row, will both bring your borate level to more or less the upper limit.
    May 2012
    Allentown, PA
    219
    Re: How much Borax?
    So the borate stays in the water through the winter?
    I read about how to add borates to help keep your pool balanced, but it seems like a lot of money for a pool that is open for 4 months. However, if I raise the borate level this year it will be in the same range next year when I open the pool more or less?
    How would you recommend that I raise the PH? Add 8 boxes this season then move to using PH+, Do the full borates treatment this season, or use aeration + ph+ when needed. Thanks for your suggestions, I'm still a noobie.
    Re: How much Borax?
    Yes, borates stay in the water. The borate level only goes down when you lose water, for example from backwashing or winterizing, or splash out.
    Why are you raising the PH so much? If you are using trichlor tablets it is better to raise the PH with soda ash. Other than that, there shouldn't be any reason to raise the PH even remotely close to that much.
    Borates are optional. If the cost bothers you then simply ignore borates.
    May 2012
    Allentown, PA
    219
    Re: How much Borax?
    Jasonlion,
    I am not using trichlor tablets. I have switched over to bleach for shock. I have just switched over to bleach last week and I'm trying to get used to it. I have to increase PH every time it rains. I understand that PH should normally rise on its own, Correct? I have just started using a decent test kit K2006, so perhaps last year I was raising ph and lowering ph often due to the fact that I was going by the results to my test strips which are inaccurate. I'm thinking about continuing to add borax as needed this season, but not going over 8 boxes. Then switching over to PH+ once I have established some form of a borate level. Does this make sense? Thanks for your advice.
    Re: How much Borax?
    If your PH is constantly falling, just raise the TA a bit and it should stop falling.
    May 2012
    Allentown, PA
    219
    Re: How much Borax?
    My TA is at 100 where about should it be? TFP says about 70-90ppm. Could you address the rest of my questions in my last post when you have a chance? Thanks again I'm just trying to get thing correct
    Re: How much Borax?
    If your PH is going down that much and you aren't using trichlor, then something is wrong, and you should figure out what and resolve it. That renders the rest of your question moot.
    May 2012
    Allentown, PA
    219
    Re: How much Borax?
    I just stopped the trichlor on Friday June 8th. so that is probably the reason the ph has dropped I also added CYA about 3 lbs. on June 8th as well. Thanks
    May 2012
    Allentown, PA
    219
    Re: How much Borax?
    Butterfly's Avatar
    South Carolina
    10,045
    Re: How much Borax?
    Quote Originally Posted by doublewide6
    Once you stop using acidic source of chlorine (trichlor), your pH dropping problem should also stop.
    You're done SLAMing when:
    Mar 2007
    San Rafael, CA USA
    12,082
    Re: How much Borax?
    Also, the Cyanuric Acid you added would lower the pH. Now that you've stopped adding CYA and adding Trichlor, the pH should stabilize or slowly rise.
