Results 1 to 8 of 8
Thread: Should "generating" light be on all the time?
    Aug 2011
    Pittsfield, MA
    106
    HAYWARD AQUATROL AQ-TROL-RJ
    I expected the "generating" light only to come a percentage of the time based on the control. It seems to be on any time the filter is on and I have the percentage control set to 1%. My FC level is up around 5 and the filter runs 12 hours a day. Is this normal?
    Rick
    24' Round AG Vinyl Pool (13,500 Gallons)
    Sand Filter, Aquabug Vacuum
    Pump Size: ?? Flow Rate:??
    Shifted from Baquacil to Chlorine 8/2011
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    Re: Should "generating" light be on all the time?
    That's what mine does; the light is on all the time regardless of the setting. I guess the light really should just mean "I'm working OK".
    Jun 2007
    Poughquag, NY
    217
    I think mine does as well. I can tell mine is really generating because of the small bubbles in the returns.
    20 x 40 vinyl IG. SWG. Solar. Ikeric VS pump.
    Aug 2011
    Pittsfield, MA
    106
    OK. Thanks. Should the voltage be different depending on the percentage then?
    Rick
    Oct 2009
    3,899
    The percentage on the dial is just the percentage of time that it's actually generating, e.g. if it's set on 10%, it will generate for six minutes per hour. The rest of the time it's just sitting there, even though the "generating" light is on.
    Aug 2011
    Pittsfield, MA
    106
    Thanks much.
    Is it possible that mine is generating 1% of the time and still keeps my FC at 5 in 12 hours?
    Eick
    Aug 2011
    Pittsfield, MA
    106
    Update: There is a bit more to the story. Two days ago, I realized that I had left the filter control on "on" rather than "auto" so the filter was running 24 hours a day. I put it on auto then and now the FC is down to 3.5. I'll continue to monitor it.
    Rick
    Aug 2011
    Pittsfield, MA
    106
    3.5 today as well.
