I have been watching the other thread because i believe i am in the exact same boat.
Just one quick question - if i shut the main drain off i should still be able to run the pump / pull enough water through the skimmer to keep it running?
I lose prime almost immediately ...... so i assume i have a clog somewhere in my skimmer line?? .... i can vacuum when both are open but it doesn't vacuum like it should.
