Thread: My Chlorine Feeder
    Sep 2011
    Omaha, NE
    95
    My Chlorine Feeder
    Just thought I would share my chlorine feeder:
    16X24 Oval Doughboy
    10,000 Gallons~
    Pentair Dynamo .75/1.0 HP pump
    16" Pooline D-400 Sand Filter w/ 6-way valve
    Sep 2011
    Omaha, NE
    95
    Re: My Chlorine Feeder
    16X24 Oval Doughboy
    10,000 Gallons~
    22,551
    Looks good. I like that you painted the tank.
    Sep 2011
    Omaha, NE
    95
    I wish now I would have put the injector sideways to prevent someone from kicking it as they walk by, but usually, I am the only one in that area. Maybe a project for the winter....
    16X24 Oval Doughboy
    10,000 Gallons~
    Nice job. Looks like you've put a lot of thought into the installation. I will add a few thoughts based on my experience for you:
    1) Bulkhead at the bottom of the bleach tank. It's not a question of if this will fail and leak; it's a question of when. Normally I would recommend using a peristaltic, self venting diaphragm, or diaphragm with vent valve and pull from the bottom of the tank with no bulkhead. However, I don't believe the pump you have is self venting and it may be less expensive to just buy a garbage can as a secondary containment to prevent leak damage than to add a vent vale to it. The lid will keep rainwater out.
    2) The tubing you are using appears to be vinyl on the injection side and white LDPE/HPDE on the suction side. Neither one of these is UV stabilized, and the vinyl isn't very bleach resistant. The vinyl will get cloudy/sticky over time and eventually leach bleach. The white will get brittle and crack from UV exposure. I'd recommend replacing both with black HDPE which is UV stabilized. I assume you've used the clear on the injection side so you can see when bleach is flowing. Just add a flow indicator to achieve that. http://blue-white.com/Products/flowIndicator.htm Even with the black tubing, count on replacing it every couple years.
    3) Keep a close eye on the pump for leaks. The diaphragm in that pump is famous for leaking. If you catch it early it is easy to fix and no big deal. However, if it leaks unchecked it will get into the motor and ruin the pump.
    21' Leslies Beachland Ag Pool, 10,000 gallons, professionally installed (best money I ever spent) Hayward 16" sand filter w/Pentair two speed pump Fafco 4x20 solar heater,Aqua Trol RJ. Borates added. Hard plumbed.
    Sep 2011
    Omaha, NE
    95
    I am trying something new on there. I put that split loom plastic (normally used for wires) around the clear tubes to protect it from the sunlight, we will see how that works out...
    Also, not sure what you meant about the venting and such, but the lid has a build-in vent on it..
    16X24 Oval Doughboy
    10,000 Gallons~
