Results 1 to 9 of 9
Thread: cartridge filter issue
    I have an 24' above ground. We just got a new cartridge for our filter- A a hayward I think its ever clear 400. 40sq ft. Any how the pool pressure rises after only a few short hours. How long should I be able to run the filter with out having to clean the cartridge. BTW- our pool is very cloudy, have yet to see the bottom this season.
    Thanks from Maryland
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,427
    Re: cartridge filter issue
    The filter is doing its job, filtering out some of whatever is making the water cloudy. It sounds like you need to complete the shock process on your pool to clear up the cloudiness. For more information on the shock process read shocking your pool and defeating algae
    After the shock process is complete the filter should go several weeks without needing to be cleaned.
    Love TFP? Become a
    TFP Supporter!
    In addition to the shocking process, I would suggest getting a second cartridge so that you can swap out a dirty one for a clean one and then do a proper and thorough cleaning on the dirty one.
    http://www.unicelfilters.com/retailers/ ... _users.asp
    Note: Most "TSP" is not real TSP (Trisodium carbonate). Real TSP works best, if you can find it.
    Also, if you can post a full set of test results, we can better assist you.
    Support the site
    thanks for the info. Im a little confused though. Do I just keep adding shock until I get the chlorine to the recommended shock level based on the chart? Im pretty sure our cya level is low. It was last week when we had the water tested and we havent been able to stabalize chlorine despite having floaters. Im going today for a test kit and a test. Will post results later.
    Jul 2009
    Houston, Texas
    9,427
    Once you have posted current test results we can help you determine how much chlorine is needed to reach shock level.
    Love TFP? Become a
    TFP Supporter!
    so here are the test results.
    saturation index .7
    tds 600
    cya- not tested (pool girl said cant test unless we have a FC reading. I tested CYA at home at got 30ppm
    fc- 0
    ph 7.8
    tot. alkalinity- 173
    hardness- 273
    thats what Ive got!
    Thanks
    Lori
    You are in the high-risk range for scaling. The high saturation index is probably contributing to the cloudiness. I suggest lowering the pH to 7.2 and keeping it at 7.2 until the TA comes down substantially. See this link for the process to lower the TA.
    pool-school/lowering%20total%20alkalinity
    Next, you should maintain shock level until you pass the overnight chlorine loss test, your water is clear, and your CC level is 0.5, or less.
    pool-school/chlorine_cya_chart_shock
    pool-school/overnight_fc_test
    The cartridge is probably scaled and needs to be cleaned according to the directions here:
    You can use the pool calculator to calculate how much chlorine to use to achieve the correct FC level, how much acid to use to lower your pH, your saturation index, and lots of other cool stuff.
    http://www.thepoolcalculator.com/
    Support the site
    thanks- looks like a fun couple of days- hopefully not weeks. The kids will love a fountain. I guess I'll head to the hardware store! So I have pool store PH reducer. Will that work the same as the dry acid?
    Pool store PH reducer is dry acid.
