Results 1 to 15 of 15
Thread: Intex 18' x48" Ultra Frame Support Question
    Hello,
    With such success on my first posts' questions being answered, here is another question:
    My Intex pool is slightly unlevel, 3 inches in the worst location, 1 1/2 in the others but I do not think this is much of a problem because it is gradual. I have a lot of action in my pool, sometimes four or five kids splashing around and the pool supports move slightly. How much should these supports be able to move? I'm not saying the legs' feet move but the legs themselves sway. With a few troublesome legs, this can worry me-I have two that have slightly sank, one that is not within the band and rope (NO clue how that happened), and two that are a few millimeters slanted. I'll post pictures tomorrow once it is daylight again but just wanted to hear some thoughts.
    The earth under my pool was dug VERY slightly (this was after digging a large garden by hand, I was done with digging) and then I added 3 tonnes of sand to help level. Like a moron, I didn't use supports under all of the feet, just the half I thought may be lower. I discovered this site after setting up the pool of course.
    Thanks!
    Marcus Kizer
    - 18' x 48" Ultra Frame Intex AGP 7000 gallons(?),
    Hayward Pro Series 21" Sand Filter and 1 1/2 HP Power Flo Matrix
    Samantha Sabrina's Avatar
    Apr 2012
    Bloomsdale, Mo
    346
    Re: Intex 18' x48" Ultra Frame Support Question
    Drain the pool, level the ground, and when you set it up again, use concrete pavers under each support leg, (I am going to use the 4" thick 8" x 16" concrete pavers), they will give much better support and reduce the odds of any supports sinking.
    At worst you should have it and keep it within 1" from level at any given point, and closer is better.
    Samantha
    In the process of building for a 22' Intex Ultra Frame, (completion date up in the air at this point).
    We could not beat our backyard into submission so we "Buried It".
    That would definitely be the way to go, but I need to find a way to fix this without draining.. It took FOREVER for the pool to heat up plus all the chemicals I've placed in it.. it'd be a huge loss.
    Marcus Kizer
    Apr 2012
    Bloomsdale, Mo
    346
    Yes it would be a big loss, but how big would the loss be if your pool folds up while your children are in or around it?
    It totally sucks that the instructions don't make it perfectly clear to people how important it is to place these pools on level ground and that they should use the concrete pavers under the supports to help prevent settling/sinking.
    Even with the pavers there is still the chance of one or more sinking and causing the pool to become unlevel, but as indicated in another thread if you start out with level and for some reason something does settle or sink on you then you can jack up the low support and bring it back to level, but trying to jack up a pool that was setup on unlevel ground is not a smart thing to do, you will be putting too much stress on the entire pool structure and liner, which could very well result in a collapse, causing serious injury, possible death, and property damage.
    The simple fact that you have 1 support leg that is not within the strap is cause enough to drain and correct the situation, I don't know what it would take to make that support move, but without that strap holding it....I wouldn't take any chances, if it were just the rope at the bottom you could untie the rope and fix that with it full, but the strap is another story.
    All things considered, it would be much less expensive to drain and make it right than to jury rig it and take a chance that it will hold up, cut your losses while you are ahead and chalk it up to a lesson learned.
    Best of luck with the choice you make.
    Samantha
    The strapless leg does scare me however there isnt any stress on it surprisingly. I weigh 180lbs and to test this setup i cannonballed into it from about 6 feet high. Im worried about the swaying.posts. If it comes down to it, ill have to drain. Just want any and all ideas.
    Marcus Kizer
    for whatever its worth, i have seen posts of people going back around the pool with ratchet strap due to rope or leg straps.
    24' Round Above Ground, Metal by SOLEX
    Heat Pump, Focus Temp INSTAMAHK 80
    Hayward S-180T Sand Filter
    Hayward Ultra Pro LX Pump
    Jamison04's Avatar
    Jun 2011
    Tecumseh, OK
    573
    Quote Originally Posted by PhilGillis
    That is exactly what I put around the bottom of our old intex pool instead of a rope. It's adjustable and a lot more durable than the rope. Heck the summer escapes pool don't even come with anything to go around the bottom! I went ahead and put ratcheting straps around the bottom of it too just to be on the safe side.
    24'x52" Artesian w/ Portifino liner - Hayward 1hp powerflo matrix w/24" sand filter - AquaTrol RJ SWG. Solar heating to come. -
    May 2011
    Saint Charles, MO
    6
    Allow me to toss my 2 cents in. I just finished setting our pool up for the 4th year in a row. Off by 2.5 - 3 inches every year. on the low side, I'll take a couple of 2x4 scraps and set them under the legs. It helps and they don't move. I wouldn't sweat the unstrapped leg. You're right in general there's not much pressure on them. I have on occasion, been able to lift one leg enough to get some sort of pad under it. Give it a try, otherwise, use a car or bottle jack and a 2x4 to lift the leg at the "T". good luck and have fun. I spend $200 /year in upgrades on my $200 pool. This year it's a new, wide ladder so all of us fat old drunks can get in and out.
    Intex 15x48, Intex Sand Filter and SWG.
    Apr 2012
    Bloomsdale, Mo
    346
    Hey dhoward,
    Good to see someone local here.
    Samantha
    May 2011
    Saint Charles, MO
    6
    Hey Samantha.
    mcoonan's Avatar
    Aug 2008
    Mendota Heights, MN
    292
    Quote Originally Posted by Jamison04
    Where the heck do you get a 60' ratchet strap?
    Intex Ultra 18' x 52" AG 6,981 Gal.
    3 - 2'x20' solar panels
    Hayward XStream 1500 Cart Filter
    Hayward 1-1/2 HP 2-speed Superpump
    Aquabot Pool Rover
    2-Softub 300 hot tubs (yup just got one for the lake)
    TF Test Kit Doing the BBB for 7 years
    Medota Heights,Minnesota
    May 2012
    NW PA, halfway between Pittsburgh and Erie in the PA snowbelt
    159
    Quote Originally Posted by mcoonan
    15 quantity x 4' ratchet straps = 60'
    Mike
    22' round Intex UltraFrame pool, Intex 633T 2500gph paper cartridge filter/pump
    with broken Intex SWG, using bleach this year
    TF-100 test kit
    Jamison04's Avatar
    Jun 2011
    Tecumseh, OK
    573
    Quote Originally Posted by mrodgers
    They are 12 or 15' ratcheting tie down straps I can't remember for sure but they are long and have rubber or vinyl like coated hooks. Here, just like these from Sam's. I got them at SAMs several years ago in a 4 pack but they were a different brand.
    I decided to go with the Hayward 21" Sand Filter and 1 1/2hp pump... It works great except I'm pretty sure I purchased the wrong silica sand... will deal with that later. At any rate, here is a pic of my work in progress pool (Pool looks very slanted but this is only because I am standing on a hill-it's only 2" off lol)
    [attachment=0:3l9frw9v]Pool 010 (800x533).jpg[/attachment:3l9frw9v]
    Marcus Kizer
    Casey's Avatar
    SW PA
    10,418
    Is that a boxer I see?!
    Oh... nice pool!
