Thread: DPD Powder
    DPD Powder
    When I use the DpD powder it does not totally dissolve. Their are clear crystals left in the bottom of the comparator. What are these? Will this effect the test?
    21,100 IG Vinyl
    Hayward Pump
    Sand Filter
    TFPC
    Taylor K-2006 Kit
    38,547
    Re: DPD Powder
    Not sure what they are but it is normal.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,075
    Re: DPD Powder
    That means you're using enough. If you don't see a couple undissolved granules before you start adding the R-0871, you haven't used enough.
    Re: DPD Powder
    Thanks!
    21,100 IG Vinyl
    Hayward Pump
    Sand Filter
    TFPC
    Taylor K-2006 Kit
