Results 1 to 13 of 13
Thread: My latest test results
    Feb 2012
    Winston Salem NC
    161
    FC = 4
    CC = 0
    TA = 40
    CH = 80
    CYA = 20 (maybe just a touch less)
    PH = 7.2
    These are my latest results, taken this afternoon. It has rained here off and on for two days, but prior to this test it had been sunny for about 6+ hours.
    My question.... asside from a few items being too low, is there any reason to be make immediate adjustments? I assume that my PH is a little low (was 7.5 last week) could be because of the rain (additional water) over the last two days? Also, my CYA is below the recommended levels for a salt pool, but I am running the SWG at 25% and the pump at 1300rpm for about 6 hours per day. Given this, my FC is still at 4. Should I still up the CYA?
    For what it is worth, my water is very clear, and I am happy with the way it looks!!!!!!
    Thoughts?
    18x36 IG Vinyl. ~29k Gallons.
    Pentair CCP420 Cartridge Filter
    Pentair Inteli-flow VS Pump
    Hayward Goldline SWG
    Tigershark QC Robot
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,023
    Re: My latest test results
    If it's clear and holding chlorine, go swimming.
    Test it again tomorrow.
    Feb 2012
    Winston Salem NC
    161
    Oh... I have been swimming, and loving it! I just notice everytime that I do my test that my CYA and TA are lower than what is on the laminated sheet with the TF-100.
    Tigershark QC Robot
    38,305
    The low TA will help hold the pH from drifting up too quickly due to the SWG.
    You probably could lower your % even more and/or shorter your pump run time if you raised up the CYA some ... no hurry if the FC is holding.
    Feb 2012
    Winston Salem NC
    161
    Ok... After a few months of owning the pool, I have done nothing other than brush it and put the tiger shark in. I do vacuum manually occasionally when I need an excuse to have a few beverages.
    With that said, my Ph stays at 7.2. My TA has held at 40. Is this normal? Honestly, I have only added CYA within the first few weeks and done NOTHING else.
    Tigershark QC Robot
    38,305
    Sounds like you have hit a nice equilibrium if your FC is staying in range.
    Likely your could make your SWG cell last a little longer if you raised the CYA and lowered the SWG output.
    Feb 2012
    Winston Salem NC
    161
    Have been meaning to add more CYA, but quite honestly keep forgetting. Only running the pump about 8 hours and the cell at 25%. Maybe both of those are considered too much...?
    Tigershark QC Robot
    Feb 2012
    Winston Salem NC
    161
    This dang pool is working me to death....
    Friday night I had to add 160 lbs of Salt to satisfy my SWG. I also had to add 6 lbs of CYA (never got it up to recomended level to begin with).
    This is a joke...
    I am very happy that $20 worth of Salt and $24 worth of CYA are the only thing I have put in the pool since it was first opened. We have had lots of heavy rains over the last month or so, so I have had to drain it down several times resulting in the low salt and CYA.
    I am loving the fact that my pool has been Trouble Free so far!
    Tigershark QC Robot
    UnderWaterVanya's Avatar
    Jun 2012
    Mint Hill, NC
    2,589
    Quote Originally Posted by head gamez
    This is a joke...
    Had me going for a second!
    Feb 2012
    Winston Salem NC
    161
    TA is still at 40, and Ph is still 7.2. Is it really supposed to be this easy, or am I in for a rude awakening?
    FC was 4.5 tonight, with no CC.
    I did not test CYA since FC was holding nicely. SWG is set to 25% and pump is running 8 hours at 1200 rpm.
    Am I missing something?
    Tigershark QC Robot
    30,424
    Good morning.
    While you have some numbers that may not quite fit the parameters we suggest, I wouldn't change a thing.
    You are obviously on top of your water management and what you are doing is working close to perfection.
    Your pool is a good example of how important it is to understand what test results mean.
    You simply cannot plug in the suggested parameters from poolcalculator and expect your pool to magically remain crystal clear. You have to learn the meaning of the tests and how to identify and manage the problems that your test results may indicate.
    You also have to know when to leave well enough alone which is exactly what I would do with your pool. Nice work!
    Feb 2012
    Winston Salem NC
    161
    Thanks Dave!
    I know my numbers aren't typical, but this site has taught me a bunch! One of the things I learned was that if it is working, then leave it alone (as long as it won't bite me downstream)! Honestly, I owe it all to the site. I stumbled on TFP while googling vinyl pool builds as I was anticipating mine to start. After that, I learned that all the stuffy friends had told me was all wrong. I learned that when my dad said to buy "shock" a SAMs or Costco, to ignore it. He has a pool and "shocks" it every week. Ha!
    I have added CYA and salt to my pool and brushed and put the robot in. This has really been easy, and without this site, I would have probably ended up all out of whack.....
    Thanks to everyone!
    Tigershark QC Robot
    Feb 2012
    Winston Salem NC
    161
    As the swim season winds down.... My latest test results...
    FC=4.5
    Cc=0
    TA=40
    CH=80
    Cya=40
    PH=7.2
    I love my trouble free 30k gallon IG vinyl pool! This site has taught me a bunch, and I owe it all to you guys.
    Tigershark QC Robot
