Thread: Need help choosing from equipment choices
    Okay...so we got the new pool liner installed over the weekend. That will have to be it's own post lol. But it's in and I think successful this time
    The pool is an older Lomart 15x30 above ground that came with our house.
    We are trying to determine whether to use the stuff that was here...IF it works, not sure it was properly winterized, versus the stuff from our old pool.
    Here is what was with the pool:
    Hayward Pro Series High Rate Sand Filter
    Not sure of the size but it's smaller than our other filter. It holds 100lbs of sand if that helps.
    These are the specs:
    Effective filter area 1.4 sq ft
    Filter rate 25 sq gpm/ sq ft
    Design flow rate 35 gpm
    Max working pressure 50 psi
    Pump - Hayward Power Flo LX 1.5 HP
    Here is what we brought with us that we got from a friend who also had a 15x30 pool, we used it on an 18' round pool.
    Clear Master Plus 19 Sand Filter Uses 150 lbs sand
    Design Flow rate 40 (assume gpm)
    35 PSI
    Pump- Pentair Dynamo 2HP
    Not sure what I am looking at as far as what should go with what for my size pool. We also have an Aqualuminator light but it needs a new bulb. Anyone know how hard it is to replace that with the pool full? Funds are a bit tight with having to buy the liner, salt, stabilizer, etc. so I'd like to wait on the bulb but will have to go ahead and install the old one since it serves as the return. Oh and we also have an Intex SWG. It worked wonderfully with the 18' pool, hoping it will work with this bigger pool.
    Thanks!
    ? 15x30 Lomart Above ground
    Re: Need help choosing from equipment choices
    Aww I thought for sure you gurus would have some words of wisdom
    about to go cut out for the skimmer and return...scary!! lol
    38,275
    The 2HP pump is overkill and will just cost you more money in electricity (in fact the 1.5HP is also likely larger than you need)
    I would also think you would be better off with the larger sand filter regardless of the pump you choose to use.
    This pool is about 60% larger than the old one assuming the depths were the same ... I am not sure what the output of that SWG is, but you may have to run the pump longer to get enough FC out of it.
    Thanks!
    I'm trying to remember how to lay out the plumbing..can someone verify this is right:
    Skimmer -> pump -> filter -> return
    I can't remember where the SWG .. I think after the pump but is it before or after the filter?
    22,548
    The swcg should be the last thing before the return. So after the filter.
