Thread: amazing it rains and water turns crystal clear, stains lift
    Oct 2010
    michigan
    284
    Amazing it rains and the water turns crystal clear and all stains lift off the fiberglass. 7.5ph to 7.4 PH, amazing how .1 Ph will remove all stains from the fiberglass.
    guessing it allows more of the water to absorb the iron
    15,000 gallon inground fiberglass pool with spa. 350lb Sand filter, 1.5 hp pump, and heater
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Re: amazing it rains and water turns crystal clear, stains l
    pH shift is known to do this
