Thread: Aqua Rite Not Producing Chlorine
    Can someone help me please!
    I just change my salt cell and my pool is still not producing chlorine. My Hayward Aqua Rite shows the power is on and is generating but no chlorine.
    My box shows:
    3300
    84 degrees
    26.2 Voltage
    xx.x Amps
    75P output
    -0
    AL-0
    r1.55
    t-3
    All of my levels on everything but chlorine are in normal range. Does anyone have any idea what could be going on.
    Crystal
    Re: Aqua Rite Not Producing Chlorine
    Could you post your current levels? "normal range" doesn't tell us what we need to know.
    You should bring the FC level up to normal levels manually to start with, and see if the SWG can maintain it from there.
    Also, what is the amp reading when the cell is active? The cell cycles on and off, so you need to make sure to look at the amps reading when the cell is turned on.
    what should the amp reading be?
