Results 1 to 10 of 10
Thread: Automatic Pool Cover issues
    Evansville, IN
    65
    We have an Undertrack Automatic Pool cover. Last year the rope pulley broke and our pool installer fixed the problem after several days. Yesterday I heard a noise while I closed the pool. Today I opened the pool cover only a few feet and tried to close it. Only one side of the cover would close. The rope pulley was broken again. Our pool is less than 2 yrs old. I always keep a pump on the cover when it is closed. I called the pool installer again and am awaiting a call back. I am hoping it is covered under the warranty. Last year my neighbor also had their rope pulley break within a few days of ours breaking and they had to pay several hundred to have it repaired. Has anyone had issues with their Automatic Pool Cover?
    36X18 Inground Pool, SWG, Hayward Pump, Hayward gas heater, Undertrack Auto Cover, Interfab basketball system, TF-100 Test kit, Polaris 9300 Robot Cleaner, Pool Completed July 29 2010
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    Re: Automatic Pool Cover issues
    Sorry to hear that! Just to be perfectly clear, it is the pulley, not the rope, that is breaking? Hopefully it will be fixed under warranty for you (and get fixed right this time!)
    Evansville, IN
    65
    I'm sorry. It is the rope that keeps breaking. I spoke with Automatic Pool Covers INC yesterday and they said critters can get in the box and chew on the rope. I looked at the rope both times and there is no evidence of chewing. They said it could be a poor install. It looks as if the rope is rubbing on something and the rope is getting frayed. The rest of the rope looks fine. I called the pool installer yesterday and of course they said they would call me back. Haven't heard back from them. Poor support.
    harleysilo's Avatar
    Mar 2012
    North Georgia
    1,924
    Quote Originally Posted by sd72667
    When i was researching autocovers, one of the biggest complaints i read about was customers upset with autocover service people blaming broken ropes on rodents "chewing through the ropes".
    This complaint is so prevalent on the web i almost didn't get a cover.
    When ours was being installed i talked to the installers about that and they laughed. The owner of the pool cover store who sold us the cover through my pool builder came by to visit and check on the final install, i asked him about that and he laughed too. Not to say it doesn't happen, i mean rats have to eat don't they?
    That said, i was instructed to either do maintenance or pay them to once a year. That included spraying out the tracks the cover slides in to prevent a build up of debris that the ropes would rub on/get dirty on. Have you been doing that?
    It would be nice to have the pit cover off and watch the cover open and close a few times and see if the rope is contacting anything it isn't supposed to be. If it is then maybe it really is a "bad install". You would think it could be adjusted.
    I also found a lot of threads about people using this Kevlar yacht rope to replace the ropes themselves, i'm sure you could find them just search.
    18'x43' Sport Pool
    19,000 Gallons Vinyl Liner 3'-3.5'-4'
    SWCG and D.E. Filter
    Test Kits - Pool Calculator - Chlorine/CYA Chart - Pool School
    Secret Weapon for Pool Chemistry Testing
    Evansville, IN
    65
    I was not offered any "maintenance" programs. I'll call around after it is repaired and check prices. I asked the manufacturer about the rope and if there is a better solution. Of course I got the "we use the best products available" bit. I will observe the pool co. when they repair it and make sure it is a smooth run through the pulleys.
    harleysilo's Avatar
    Mar 2012
    North Georgia
    1,924
    Here was the once a year maintenance recommendation from the owner...
    For +- $3?? they would come out and ....
    1) Clean out cover tracks with water hose
    2) Spray proprietary cleaner (told me i could use any citrus based cleaner from HD) all over cover and use pool brush to scrub cover. Rinse and use pool cover pump to discharge water into pit drain. Wrap towel(s) around pool brush and dry cover. Spray down cover with proprietary protector (told me i could use 303 Protectant).
    3) Remove Pit cover and clean pit and vacuum it.
    4) Grease few spots/fittings that need grease
    5) Adjust rope(s) or anything else if needed.
    18'x43' Sport Pool
    Evansville, IN
    65
    Thanks, I can do all of those items. I already open and close my pool. Just basic preventative maintenance. I already make sure the pit cover is empy of debris. I will read the manual and grease the fittings and etc... My pool installer has to order the rope. Is there a special "Wonder Woman" rope they are using? I'm sure any hardware store has the rope. It will be a week before they are out to fix it. Thanks for the replies.
    harleysilo's Avatar
    Mar 2012
    North Georgia
    1,924
    Did you say exactly what brand cover you have?
    It is my understanding that they do indeed use a special "Wonder Woman" type rope. In fact the manufacturer of the cover i bought developed some brand new super duper rope in 2011 here is a marketing quote http://coverstarcentral.com/pdf/newslet ... y_2011.pdf
    "PowerFlex Rope
    PowerFlex rope is the next generation in autocover
    rope technology. As a result of a proprietary
    treatment process, PowerFlex rope behaves like a
    shock absorber. This allows the rope to be more
    forgiving and self adjusting during operation. Our
    new and improved rope also resists stretching and
    distortion common with autocover ropes.**PowerFlex
    Rope is easier to install and operate with fewer
    adjustments. The new PowerFlex ropes are black
    which blends into the track.* *A special coating adds
    lubricity to minimize friction along the track."
    SURE SOUNDS LIKE SPECIAL ROPE TO ME!!!!
    In all seriousness what i've found on the web about DIY'ers fixing the ropes themselves is that they get this special Kevlar rope used in Yachting that works good (but not with a Salt water pool apparently). here is some reading http://x.havuz.org/viewtopic.php?p=30970
    18'x43' Sport Pool
    Evansville, IN
    65
    Automatic Pool Cover INC. out of Indianapolis or Fishers Indiana. http://www.apcmidwest.com/Default.aspx
    Evansville, IN
    65
    I wonder if the salt water has any effect on the rope. It corrodes everything in its path, screws, basketball goal etc...
