Thread: it is possible to bleach out the chlorine test?
    Jul 2010
    minneapolis, mn
    31
    Ok so yesterday I added bleach cause my Chlorine levels dropped down to .5 again (no signs of algee that I can see) and I should have added enough to get it up to 15. This morning it is back down to 0 again. it was moderate sun yesterday
    Yesterday I also added Borax and muratic acid to add borates about a hour afterwards. I am not sure I added enough acid becuase I ran out of bleach and acid and had to run to the store and when I went to put more acid in...the numbers didn"t seam right so I added in the borax as it called for, but held off on adding more acid until i can test it because I didn"t want to put in more than needed but didn"t trust my numbers from earlier.
    So here is where I sit, I tested everything however per the document on adding borates I should hold off on testing after adding the borates stuff until 48 hours it has only been 24 hours...so maybe that is why?
    I was just going to check Chlorine today, but when that was zero I checked everything
    TC 0 oto came back .5
    I get a slight pink tinge when I added the FC drops into the chlorine test (hope that makes sense)
    PH 6.8
    TA 80
    CYA 45
    Borates 50
    so my chorline is being knocked down significantly, assuming the test is accurate but oto was close So I can assume that all is good. Where do I go next PH I am guessing can wait until I retest tomarrow which would be 48 hours after adding borates.
    Today I am guess getting the chlorine back up.. should I take it up to shock level. it was below 1 for less than 24 hours and it did rain two inches on sunday. Which is why i wanted to bring it up to 15 yesterday but it burned through that.
    12'x30" Intex AG 1,485g pool, w/530gph cartidge filter
    22,553
    Re: it is possible to bleach out the chlorine test?
    I'd bring the pH up and then then bring the FC to shock level.
    Jul 2010
    minneapolis, mn
    31
    Would raise ph by arerating then? Since everything but PH and Chlorine is about right?
    22,553
    I'd start there. That won't affect your TA that way.
    Get your PH up to at least 7.0 soon. Your PH might be well below 6.8, since the standard PH test reports any PH below 6.8 as 6.8.
