Page 2 of 2 FirstFirst 12
Results 21 to 30 of 30
Thread: Algae or Just Pollen and or Dirt?
  1. Back To Top    #21
    Jun 2007
    Long Island, NY
    34
    Re: Algae or Just Pollen and or Dirt?
    I am going through the same issue. I have been fighting this battle for 3 years now. Everyday I vac the pool and by the next morning I have the spots in the depressions of the liner. They look greenish in color. They vac easily and will dissipate if I brush them. I keep my levels right where they should be. I have done the overnight chlorine test and that too is fine. I added sand to my filter this year to bring up to the proper level as all the backwashing last year I lost a bunch. I was hoping this would help but it has not. I am at a loss as to what this stuff forming on the bottom of the pool could be. This is very frustrating as all my test and levels are indicating there is no algae in the pool but these spots show up every morning.
    Brian
    18' round x 52" vinyl AGP holding aprox. 7633 gallons of crystal clear sparkling water, most of the time. Hayward s166t sand filter, 1 hp pump and 2-2x20 Fafco panels is parallel. TF100 test kit and BBB!
  2. Back To Top    #22
    Sep 2011
    Omaha, NE
    95
    Well, if my guess is correct, and my situation is the same as yours, then the problem is inside the filter. I am not sure what your innards look like on your filter, but I think mine must have a small crack in the tube/pipe that leads from the bottom laterals up to the top of the filter where it then exits to the pool return.
    I just tried putting 5 cups of DE on top of my sand, thinking that the sand was not trapping the "fine silt" and my only conclusion is the pipe. My pool is clean during the day until I turn on the filter.
    On a plus note, my water is very clear now that I put that DE in trapping the small micron stuff!!!!
    16X24 Oval Doughboy
    10,000 Gallons~
    Pentair Dynamo .75/1.0 HP pump
    16" Pooline D-400 Sand Filter w/ 6-way valve
  3. Back To Top    #23
    May 2012
    Houston, TX
    17
    I seem to be having the same problem for the past 2 weeks. The greenish tinge puffs up like a cloud even when I just plonk the brush in the water,i.e., it brushes off fairly easily. Between my husband & me, we have been testing the water everyday now, brushing 1-2x/day, tiger shark running 4-8hrs/day, pump running 12 hrs. My numbers have been good (2-week range): FC 3-6, CC=0-0.5, CYA 30, TA 80. Even w/ shocking 2x (passed all criteria), the "dust cloud" just comes back. Should I just shock again, raising it to mustard shock level this time?
    Husband & Wife team from Houston, TX
    18k, IG pool, w/ pebblesheen
    Hayward Ecostar 1hp variable speed pump (for pool)
    Hayward Super II pump 2hp (for sheer descents)
    Another (?) pump for swim jet
    UltraPure Ozonator
    Swimclear Cartridge filter
    ProLogic Control
  4. Back To Top    #24
    22,553
    If you passed the OCLT, it's probably just dust.
  5. Back To Top    #25
    May 2012
    Houston, TX
    17
    Yup, passed the OCLT 2x.
    And surprisingly, when we had rain 2days in a row, the pool water got crystal clear. Is that another indication that this could just be dust?
    I'm at my wits end!
    UltraPure Ozonator
    ProLogic Control
  6. Back To Top    #26
    dattia's Avatar
    Jun 2008
    West Chester, PA
    511
    I am battling this as well, but have made significant gains this week. I have placed 2 skimmer socks in my skimmer (not sure how inground systems work, so this may or may not be possible for you). I rinse them several times per day as they are really trapping the gunk. I also throw a pair of pantyhose in on top of those two skimmer socks when I vacuum for an extra measure. Last week I had this silt spread out over the entire pool...enough that every pass with the vacuum left a visible 'clean' path. Each day has been getting better, the water is now clear and sparkling. Today when I went out, there are just a few little random spots.
    My problem is stemming from a filter issue that is allowing dirty water back into the pool during vacuuming... and while I haven't solved that issue, attacking the problem from the other side of my filter (at the skimmer) has proved to be working for me. I have a sparkling pool... and that is what I wanted. This approach may work for you too.
    27' round AG
    Hayward Matrix 1 1/2 HP Pump
    Hayward S210T Sand Filter
  7. Back To Top    #27
    jule's Avatar
    New London, Wisconsin
    139
    Quote Originally Posted by dattia
    I've used the skimmer socks during opening, but will begin following your tip here dattia, to see if that helps. Thanks for suggesting it!
    22 ft octagon, inground, 4 ft ave depth - figured @ 11,400 gallons, well water
    Steel walls with sand bottom and vinyl liner : under full sun
    Harmsco Betterfilter w/14 paper cartridges
    1 hp Hayward motor
    Baqua to Chlorine in 2010.
    ~Wisconsin~
  8. Back To Top    #28
    I am having a similar issue as the person in Okla. I am in northeastern Okla. What is DE? Is this similar to sand only coarse?
    Dave
    Santa Clarita, California
    1) 22000 gallons
    2) Jandy cartridge filter
    3) IG (in ground), 6 years old
    4) pebble tec
  9. Back To Top    #29
    I think I got it. Media that goes in a DE filter system
    Dave
    1) 22000 gallons
    4) pebble tec
  10. Back To Top    #30
    22,553
    Yep, you got it. It's Diatomaceous Earth.
