Results 1 to 20 of 20
Thread: Pump Motor 'Frozen'
    Athlon646464's Avatar
    Jun 2010
    Uxbridge, MA
    63
    Pump Motor 'Frozen'
    This morning I shut off the motor to change the valve to the backwash position. When I turned the motor back on, all I got was a humming noise. I've tried it with the valve in all positions.
    The motor felt hot to the touch, by the way.
    I let it cool down for about 90 minutes and tried it again, but I still get the humming noise and it's still 'frozen'.
    What should I do next?
    21,100 gallons - Hayward S-180 Sand filter - IG Vinyl - 3/4 HP Hayward Super Pump - Hayward Vari-Flo XL Valve that says rated for 75 gpm on it.
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: Pump Motor 'Frozen'
    A new capacitor may be in your future. It's a cylindrical black thing under the rear cap on the motor. The biggest thing under there.
    First check that the impeller isn't jammed. Shut the power off and see if you can turn the impeller with your fingers through the pump basket.
    bobodaclown's Avatar
    Apr 2011
    Murrieta, CA
    2,360
    at the back of the motor take off the cover and see if the shaft will turn. If it does it may be the start capacitor.
    Here's video that may help:
    http://www.youtube.com/watch?v=k-cVgpz7GYQ
    http://www.youtube.com/watch?v=ZEIv5ClLqXg
    Hope it helps. It may be a $20 fix.
    Jun 2010
    Uxbridge, MA
    63
    Thanks guys - the shaft does indeed turn.
    I'm a little nervous about touching the capacitor after reading that they can explode and/or hold a charge. I'll proceed carefully. The videos helped.
    SW Indiana
    9,199
    If the cap is bad, it won't hold a charge, but short it out to be sure. If you have a multimeter you can test it once you have it unhooked and discharged, but they fail so often anymore it's probably worth getting a new one anyway.
    Jun 2010
    Uxbridge, MA
    63
    Okay - I've removed it! Now I just need to find someone nearby who sells these things........
    SW Indiana
    9,199
    Quote Originally Posted by Athlon646464
    A pool store would be the first shot. Motor repair place next.
    Jun 2010
    Uxbridge, MA
    63
    I've been told by a local guy that I can use one with a higher rating than mine, which is 124-149 MFD. He says I should be fine at about 160-190 (I forget the exact numbers he gave me over the phone), as long as it is the same physical size.
    And you say?
    22,550
    He's probably correct. Going a little over isn't going to hurt anything.
    Make sure the voltage rating is equal or higher than the original too.
    Jun 2010
    Uxbridge, MA
    63
    Thank you all for getting back to me so quickly here this morning! I'm off to go buy it ($10).
    I'll let you know when it's installed and working.
    Jun 2010
    Uxbridge, MA
    63
    New capacitor didn't help. It's making exactly the same humming sound as this morning.
    22,550
    Does the motor have a set of contacts at the back end?
    They could be corroded. If they're there, take an emory board and file them a little. Also make sure the mechanism isn't stuck.
    Jun 2010
    Uxbridge, MA
    63
    Everything looked clean when I took it apart. Earlier today I stuck my finger in the hole in the pump basket and could turn the impeller.
    I can post pictures if that would help.
    22,550
    Post a pic of the back of the motor with the cover removed.
    Jun 2010
    Uxbridge, MA
    63
    Here you are........
    Looks pretty clean. See those 4 big bolts that hold the motor and the first black flange to the pump basket body? You can undo those and remove the business end of the pump where you can inspect it and see if it will run (just a quick on and off test) when pulled out of the basket end. If it still buzzes and doesn't run, you have a motor problem.
    22,550
    See those two copper strips that meet at the center of the motor? Take an emory board and clean the contacts between them a little. See if that helps.
    Jun 2010
    Uxbridge, MA
    63
    It started to rain here and my day job just got crazy busy. I'll keep you updated on my progress. Thank you for all of your help.
    Jun 2010
    Uxbridge, MA
    63
    Got it going!
    I braved the rain and went out and took it apart. I did what Mainecoons & Bama Rambler suggested and put it back. Walaa!! It came back to life!!
    Thank you all again for your help! I learned a lot here......
  20. Back To Top    #20
    22,550
    Glad you got it fixed.
