Results 1 to 7 of 7
Thread: Does pool heat better with/without cover?
    This is probably a silly question but which is better to let the sun heat the pool. I can make arguments for both. (I have a dark blue auto cover). if the cover is on it keeps the heat in. if the cover is off it alows the sun to hit the water directly. which way do you think will cause the water to heat better?
    Jeremiah Hough
    22,000 gallon, vinyl liner, chlorine, with auto cover
    harleysilo's Avatar
    Mar 2012
    North Georgia
    1,924
    Re: Does pool heat better with/without cover?
    Cover on! Pool pump running while your getting sun.
    automatic-cover-observations-coverstar-t46899.html
    18'x43' Sport Pool
    19,000 Gallons Vinyl Liner 3'-3.5'-4'
    SWCG and D.E. Filter
    Test Kits - Pool Calculator - Chlorine/CYA Chart - Pool School
    Secret Weapon for Pool Chemistry Testing
    jccams's Avatar
    Dexter, MI
    95
    If there is no cover will it heat better during the day with pump running or not. Does it matter?
    24,000 gal vinyl Lazy L, 1 hp pump, DE Filter, Pentair 250K heater, Letro Legend pressure side pool sweep
    For best heating, the cover should be on when the sun is not shining directly on the water. When the sun is shining directly on the water you are usually better off with the cover off, though that isn't quite always true (lots of wind tends to make a cover worth it even when sunny).
    mickey4paws's Avatar
    Apr 2009
    S.E. MI
    570
    Mostly I keep my cover on during the day if it's going to be windy in order to keep all the leaves and junk out. I also think it heats it better. I cover it at night because it seems to hold the heat in better than uncovered.
    I do wonder if keeping it covered most of the time isn't good, like does the pool need to breath?
    IG 12' x 39' - 20k Gallons - Vinyl Lined - StaRite Cristal-Flo II 26" Sand Filter - Hayward SuperPump 1 hp - Dolphin Dynamic autocleaner - Lochinvar Energyrite gas heater - Aqua Rite SWCG T-15 - TF100 Test Kit - Skimlite Duallly 9016 pole (great pole)
    harleysilo's Avatar
    Mar 2012
    North Georgia
    1,924
    Quote Originally Posted by harleysilo
    I should state that this is my first pool and first pool season so my experience is limited.
    We bought the auto cover to keep our kids and pets safe. The side benefits being limiting chemical use, reducing evaporation, virtually eliminating debris in the pool and heat retention (all though I was told a bubble wrap blanket works better for this).
    That said I only uncover the pool to swim or run the polaris. So my pool has been on average covered for 20-22 hours a day (except on weekends where we may swim longer but still cover when not swimming/running polaris).
    What I have noticed is that with the pump off and pool covered on sunny day, when I open the cover and start swimming the top 12" of water is super hot, and the bottom couple feet is noticeably cooler. With the pump running while cover is on and it is sunny, when i uncover and get in i don't notice this layer of superheated water. I my a comment to the Coverstar rep about how hot our pool was and he asked me when my pump ran. At that time it was running 24/7, I told him and he said that's why it's getting so hot. Then he explained to me what I've now discovered on my own. If i want to heat up the pool run the pump with cover on and sunny causing the water at the top that's getting so hot to circulate bringing new water to top to heat etc. If i would like to minimize the heating on sunny day with cover on turn off the pump so that the water doesn't change out below covers surface.
    Unfortunately at this time i have no experience without the cover on, but if my pool keeps getting hot I might have to start leaving it uncovered during the sunny afternoons (because i think it would be more apt to not heat up as much without cover), but that may indeed be completely wrong as Jason mentioned above baring wind conditions.
    18'x43' Sport Pool
    harleysilo's Avatar
    Mar 2012
    North Georgia
    1,924
    Quote Originally Posted by mickey4paws
    I was told that the only time I needed to leave it uncovered was when chemicals are out of wack, meaning when I'm shocking the pool. This is to prevent damage from high chlorine levels that could impact the cover.
    Bottled water comes with a lid, no?
    18'x43' Sport Pool
