Results 1 to 10 of 10
Thread: Topping Off?
    Guest
    Topping Off?
    Just curious as to how often people have to top off their pool water? Right now it seems I am having to top off once or twice a week with the weather being cooler in the evenings and no cover at this point and also have kids swimming everyday.
    22,553
    Re: Topping Off?
    Right now i won't need to top it off for a few weeks but in a few weeks when it stops raining, I'll probably have to add water about once a week.
    If you're concerned about a leak, you can run a bucket test to make sure it's just evaporation you're seeing.
    Guest
    Re: Topping Off?
    Me and my husband were just talking about doing that tonight. It has been very dry here in the Chicago area, and is still getting cool in the evenings. I am hoping its just evaporation, as we just did a DIY install of a new vinyl liner.
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: Topping Off?
    I'm adding a lot more water this year than is normal. Going through muriatic acid by the truckload with my high TA fill water.
    Jun 2011
    Ridgefield, CT
    73
    Re: Topping Off?
    I haven't needed to top off, but that is because we have had a crazy amount of rain over the past 3 weeks. Last week, when the weather turned cool, I saw a noticeable decrease in my water level, but still not enough to warrant topping off. I am always grateful for rain to help top off because we have well water, which is hard, although at least it doesn't screw up our pH or alkalinity much.
    33,000 gallon plaster pool
    Jandy L-Series -CL580 Cartridge Filter
    Re: Topping Off?
    Dont't know if this helps DeeMack, but I'm in Central Illinois. It has been sooooo dry and windy here! I am topping off the pool far more often than what was normal last year. I think it is evaporation.
    30000 gallon inground gunite pool
    Intelliflo ic-60 SWG, pentair tagelus sand filter, 1.5 hp whisperflo pump, tf 100 test kit,
    2 kids(tl), 1 mini-dachshund/lab mix(t),
    Central Illinois
    Guest
    Re: Topping Off?
    Thanks "tltmom".......I am 30 min. south of Chicago, in Indiana and we have the same issues here. My grass pretty much looks like straw and we have had alot of wind....I am going to try the bucket test tonight but again it is going to be cool tonight and only in low 70's tomorrow....urghhhhhh
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    Re: Topping Off?
    If we go a week without rain during the Texas summer, I top off 1-2 times per week. However, I do a lot of lap swimming nearly every day (at a rapid pace) and there is a fair amount of splash out, including water splashing up against (and going down) the overflow drain. My wife's water aerobics workouts add to the splash-out. There's also bound to be some evaporation going on as well, not to mention the water loss due to occasional back-washing of the filter.
    I keep my pool operational during the winter even though it is too cold to swim in. I rarely, if ever, have to top it off during the off season.
    There is an article on Leak Detection here, including the bucket test.
    Jamison04's Avatar
    Jun 2011
    Tecumseh, OK
    578
    Re: Topping Off?
    Different part of the country but for reference I have to top off about once a week right now and we've been in the upper 80's low 90's. Once it gets hotter I'm sure it'll be more frequently. Last year it was several times a week during the 3-month long 100+degree heatwave!!
    24'x52" Artesian w/ Portifino liner - Hayward 1hp powerflo matrix w/24" sand filter - AquaTrol RJ SWG. Solar heating to come. -
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,074
    Re: Topping Off?
    It seems to vary more with wind than heat. When we get a lot of wind here, especially those Santa Ana Winds that cause brush fires to go wild, I lose a lot. 1/2" a day. If it's still, even if it's 90 degrees or better, it's more like an inch a week,
