Thread: skimmer with double gasket in intex frame pool
    Hello i'm interested . I have a skimmer with double gasket also in intex frame pool . Which is the correct mounting ? In an intex frame pool ? It haven't got faceplate , only liner .
    How tips for make cut the hole with 3/4 pool filled?
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: skimmer with double gasket in intex frame pool
    Welcome to tfp, xavifm
    This link has great information for intex pools including information of adding through wall skimmers: http://www.troublefreepool.com/usefu...rs-t29612.html
    mcoonan's Avatar
    Aug 2008
    Mendota Heights, MN
    292
    Not sure if I would cut a hole that large with the pool 3/4 filled. I cut mine before I put any water in.
    The liner/wall of the pool goes in-between the wings of the butterfly gasket.
    Intex Ultra 18' x 52" AG 6,981 Gal.
    3 - 2'x20' solar panels
    Hayward XStream 1500 Cart Filter
    Hayward 1-1/2 HP 2-speed Superpump
    Aquabot Pool Rover
    2-Softub 300 hot tubs (yup just got one for the lake)
    TF Test Kit Doing the BBB for 7 years
    Medota Heights,Minnesota
