Thread: Is this really normal?
    Apr 2012
    South Mississippi
    4
    Since opening our pool a month ago with the BBB method, I add bleach, brush, vacuum and enjoy! I wish I'd known about this method over the past 11 yrs of owning a pool. I test chlorine and ph levels daily...the rest, I test weekly (and adjust as needed), the most I've had to add/adjust is the chlorine and it varies from 3-4 cups every other day. I do, however, have a question...since I'm keeping my levels where they need to be, do I need (is it recommended) to add algaecide weekly?
    Susan~
    7,600 gallons, 18x48 round AG, Vinyl Liner
    18.5" Sand Filter
    Hi-Flo Waterway Pump
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,009
    Re: Is this really normal?
    It's normal for me and I've never put algaecide in my pool.
    My pool survives on muriatic acid, 12.5% sodium hypochlorite, and 3" trichlor pucks when I leave town. That's it.
    So do you only add it if algae shows up? I was wondering about this too.
    -J E F F-
    Intex 14' round 48" deep above ground pool
    HTH 6 way test kit
    Intex Krystal Clear Sand Filter 1600g/hr
    I live in southwest Missouri
    Richard320's Avatar
    Jan 2010
    19,009
    Algaecide is only useful if you close the pool for the winter or you're on vacation and want some insurance. Otherwise it's not needed. It's just more profit for the pool store.
    22,550
    If you keep the FC in the recommended range all the time, algae will never show up. I've never had algae and have never shocked my pool or added algaecide for it. It's completely unneeded if you keep your FC where it needs to be.
    Jun 2011
    Ridgefield, CT
    73
    I think we added algaecide when we closed our pool last fall. But, once I started using the BBB method, I did not add algaecide. We opened our pool to serious swamp conditions 2 1/2 weeks ago and I did not add any algaecide, just a whole lot of cal-hypo and bleach and some stabilizer, which was the bottleneck in my shocking process. It took about 2 weeks, but we finally we good to go over the weekend.
    On an ongoing basis, all I add is bleach or cal-hypo if I need the CH, baking soda on occasion and tri-chlor on vacation.
    33,000 gallon plaster pool
    Jandy L-Series -CL580 Cartridge Filter
