Thread: Is it normal for a above gound pool to settle
    Hello, Had a new 24' x 52" professionally installed about 3 weeks ago. Needed to bring back side of pool up 11 inches or so to be level. 3/4 stone and stondust mix for base. Second was all stonedust then the sand, all was leveled with a lazer . After some heavy rain on and off for a week or so I noticed the water looked lower on 1 side, found about 1/2 inch difference. After it was installed it was pretty much even all around. Is this normal for some settling or should I call back the installer. Any thoughts would be great. Thanks for your time..
    IG Vinyl, 25000 Gallon, 28" Pentair Sand Dollar SD80 75 GPM flow rate. 1.5hp Pentair Superflo, Intellichlor IC40 SWG, Pentair Legend II pool cleaner complete as of July 2,2012. 1st pool!
    Re: Is it normal for a above gound pool to settle
    Welcome to TFP!
    Yes, that is normal. A variation of 1/2" or even a full inch is fine and to be expected.
    Thanks for the reply. You have just taken 1 more thing off this overloaded mind..
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,643
    Confuscious say: Always better to dig down than build up.
    22,553
    It's especially normal when setting ~110,000 lbs of water on a built up area. Keep an eye on it and if it settles more you need to do something about it. I'd [s:1pt0k12r]call[/s:1pt0k12r] write the installer and let them know that it settled some. That way you'll be on record about it.
    I'm not trying to scare you, because it's probably done all it's going to do, but better safe than sorry.
