Results 1 to 11 of 11
Thread: Separate pump for water features
    Jun 2012
    Austin, TX
    97
    My PB wants to give me 3 pumps for my pool. I'm wondering if they are all necessary. Info below.
    95 perimeter ft in ground Gunite pool approx 17,000 gallons - 2 HP 2 speed pump
    2, 18" water shears in a raised wall - 1 HP pump with wall switch
    Polaris 280 - 3/4 HP booster pump
    Are all of these necessary or will fewer pumps do the same jobs???
    32x15 freeform gunite pool (approx 15,000 gallons) with a 7x7 raised spa with 2 spillovers - tanning ledge with 2 bubblers - All Hayward Equipment - ARQ15 SWCG - 400btu heater, 60sq ft DE filter - 2HP EcoStar VS pump - Oklahoma flagstone coping - MasterTile MASMIX 3 1x1 - Sundek - Crystal Stones Smooth Caribbean Blue - TF-100 - Doheny's Discovery Robot
    Re: Separate pump for water features
    The Polaris 280 needs a booster pump. There are other pool cleaners that will work without a booster pump, but the 280 is a really good cleaner.
    It is possible to combine the other two pumps into one, but doing so will require a variable speed pump and it will probably be more trouble getting the plumbing right than the small up front savings will ever pay for.
    Jun 2012
    Austin, TX
    97
    If they are already doing 2.5 inch plumbing do you think it would be worth it to get the variable speed instead of the 2 speed? Would that would eliminate the need for the extra 1 HP pump?
    Jun 2012
    Austin, TX
    97
    OK...I talked to my PB and he said the variable speed would not work for my water features and that the 2 water shears need their own separate pump. Is this true?
    I really appreciate any help!
    Mar 2011
    Houston, Texas
    413
    Not sure what water shears are, but I have two fountains on my tanning ledge (which I rarely use) and I do not have a separate pump. I put an automatic valve actuator on the returns that go to the water features and with my 2 hp pump they can hit 4+ feet high if I let them. However, I do have a spa and I can't run the spa and the water features at the same time because all of the water is returned to the spa when I'm in spa mode. If you have a spa and wanted to run it and the water features at the same time my guess is that you would need a separate pump.
    My pool was designed with separate pumps, one for the pool/water features, and a larger pump for the spa. But when my pool builder quit and I had to finish the pool myself, the plumber told me I could get by with one pump so I returned the other pump. I don't care that I can't run my water feature when the spa is on.
    9,200 gal. Gunite Luna Quartz French Grey pool with spill over spa, two fountains on tanning ledge (rarely used)
    Pentair Whisperflo 2HP, Pentair CCP Cartridge 420 Sq. Ft., Polaris 280 with booster pump
    Pentair EasyTouch 4, RayPak LoNox 266k Natural Gas heater, Aqua Rite SWCG T Cell 9, Borates, TF-100 test kit
    22,550
    Why did he say the variable speed pump wouldn't work for the water features?
    The variable speed pump is a 3 hp pump and will put out a lot of water. Unless the wall with the shears is raised awfully high I can't imagine it not working. How much head do the shears create? High head & high flow requirement is the only thing I can think of that would rule out the VS pump.
    The Pentair Intelliflo VS will do 100 gpm at 80 feet of head.
    Quote Originally Posted by jk7228
    No, that is not literally true. It is certainly possible to share the main pool pump. That doesn't mean that combining the two pumps is a good idea. There are some significant advantages to having separate pumps.
    Why do you want to combine the pumps?
    Jun 2012
    Austin, TX
    97
    I don't necessarily want to combine the pumps...I just want to make sure I'm getting the best system for the pool.
    Of all the bids I've gotten, this PB is the only one telling me I need two pumps so it gets a little confusing for a newbie like me
    When you have two separate pumps you need a separate water source for the water feature pump, typically a second set of main drains. Other than that, the pumping is much simpler with separate pumps with the water feature pump sourcing from it's own drain and going straight to the water feature.
    When you combine the pumps there is only one set of drains/skimmer(s) and one pump but everything else gets a little more complicated. Typically the filter needs to be much larger, to handle the extra water flow, and you have to have a valve to determine of water goes back to the pool, or both back to the pool and to the water feature.
    Jun 2012
    Austin, TX
    97
    Thank you to everyone for all of your advice!
    Jason - I checked my bid, and it only has one set of main drains, 2 skimmers, and 4 returns. Is that a problem when you have 2 pumps?
    As is see from the date of your question,your pool is finished, and now you can see why a separate pump for the sheet falls was needed.. Keeping other appliances out of the loop let the water feature always perform as it should.
    Enjoy your pool(when it warms up)
    15x32 16k Gal IG riversand (pebblesheen) pool, Filter: Jandy 48 sq ft DE filter, Circulation Pump: Stealth Pump 2 hp 2 speed, SWCG, Heater Size and Electronic Ignition: Jandy LRZ400 Natural Heater, Cleaning System: Polaris 280, Spa: 8 Jets, 1 fountain, Polaris 220V 1.5HP QT blower
