Results 1 to 9 of 9
Thread: Equipment Bid
    Equipment Bid
    Ok Pros... I would like a price on new equipment here in so cal. I feel like my local "pool guys" are out to lunch. Please give me some numbers! purchase and install pentair intellifo, pentair mastertemp 400,000btu, 2-2" 3 way jandy valves, rainbow chlorinator, and backflush valve. All installed. I would love to hear a realistic bid, as this is becoming a DIY project very rapidly.
    Intex 16'x48" Metal Frame Above Ground. 5061 gallon.
    Two 1000 gph/750 flow rate Intex cartridge filters.
    Memphis, TN
    my-2-years-2-pools-build-project-in-pics-t44761.html
    Melt In The Sun's Avatar
    Oct 2009
    3,879
    Re: Equipment Bid
    medic, how bout you just tell us what you were quoted? You can see what things cost with just a few quick internet searches, and imagine a reasonable install fee on top of that...
    Re: Equipment Bid
    Ok. After pricing out my equipment I came to a total of 2,875. no tax, free shipping. I have received one bid of $4,100, and on for $4,075. I feel the labor rate, in which is not broken down in the bid is too high.
    Memphis, TN
    Oct 2009
    3,879
    Re: Equipment Bid
    If that is including complete setup and plumbing of the equipment pad, I don't think its too bad.
    Re: Equipment Bid
    I guess I feel that $1000.00 for a day worth of work is too high.
    Memphis, TN
    Oct 2009
    3,879
    Re: Equipment Bid
    I agree! I'd be doing it myself for sure. If you decide to do it, feel free to ask questions along the way.
    May 2011
    Orange County, CA
    696
    Re: Equipment Bid
    I'm not seeing a filter, so I guess we can assume this is a replacement? What's in there now? I'd check with a couple more pool techs to find a lower install price, or do it myself. Remember that you'll also have to haul off the old stuff. If this is to replace existing equipment, it likely means minimal plumbing and electrical changes, so it should be relatively straightforward.
    38K in ground pool with attached spa. Current equipment: Easytouch 8 (521150) with IC-60 SWCG with web control by Autelis, 1x Pentair IntelliFlo 011018 pump (for filter), 1x Pentair 2HP WhisperFlo pump (for waterfall), 2X Pentair IntelliBrite 5G 12V lights, Pentair MiniMax400 NG Heater, Pentair SMBW2060 DE filter. Zodiac Barracuda MX8 cleaner on dedicated cleaner line. Lighting/home automation controlled by Insteon/ISY-99i.
    Re: Equipment Bid
    The filter is new..circa 2006. so I am keeping it. The heater had been removed years ago, so the only thing other than plumbing I would need to haul off is the pump. Lucky for me the entire thing is brass, so maybe I can a few bucks for it. I agree I think I am going to do it myself, should be too bad.
    Memphis, TN
    Re: Equipment Bid
    Quote Originally Posted by xxxmedicxxx
    why do you feel it is too high? what are you basing it on?
    17,800 gallon, IG pool, 595 sq feet (17x35x4.5 avg rectangle), Hayward 525 cartridge filter, diamondbrite, 2 hp 2 speed hayward tristar filter, Stenner 45mhp10 automatically chlorinating
