Thread: Gray water in hot tub - tons of tiny bubbles
    Jun 2011
    Boston, Massachusets
    5
    Hi, every time we turn the heat on in our pool, the water in the hot tub is filled with tons of tiny bubbles, making it look gray. Just to be clear - this doesn't happen when I'm in spa mode and the heat is on for the hot tub. Can anyone offer any advice? Is it something I should ignore, I do not believe it happened last year (we're in our 2nd year with the pool) and I want to make sure I'm on top of any potential issues. Thanks in advance! Martap
    21,200 gallons/ cartridge filter/ inground pebble tec pool and raised spa (same equipment)
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    Re: Gray water in hot tub - tons of tiny bubbles
    Hm, I have no idea. So it happens with the heat on in pool mode; is the spillway on at this time?
