Thread: Installing a railing-No current holes in concrete
    Glock30's Avatar
    Apr 2012
    Massachusetts, USA
    90
    All,
    I am almost done with my complete pool rennovation.
    One of the last things I need to do is to install my S.S. handrail at my 6' wide stairs.
    Here is the issue:
    There are no holes in the concrete to recieve the two end pipes.
    Can I....
    #1 Simply drill the holes at the correct location and call it done-or do I need to install some type of anchor in the drilled holes?
    #2 Manufacture a S.S baseplate with two reciever pipes sticking up to hold the rail, and mount that to the top of the concrete .
    #3 Other method I have missed.
    Thanks
    18' X 36' Inground Pool 26,000 gallons. SuperMax 27mil/27mil Vinyl Liner-Installed Fall 2011
    Pentair Intellipro Programable Pump (Model 011018) // Pentair S8M 500 Cartridge Filter // Circupool RJ45 Salt Chlorinator
    2 Hayward Skimmers // 3 Returns // 2 Savi Melody Pool lights // TF-100 Test Kit.
    Mod Squad JohnT's Avatar
    SW Indiana
    9,198
    Re: Installing a railing-No current holes in concrete
    Don't forget that the railing needs to be bonded.
    There are surface mount anchors http://www.inyopools.com/Products/19801 ... 003=906191
    http://pooltool.com/images/catalog/146.jpg
