Results 1 to 10 of 10
Thread: Aqualogic - which one for me?
    Jul 2007
    North of Dallas
    207
    One main pump
    One heater
    Spa (with pump valve and a drain valve)
    2 skimmers/valves
    1 main drain valve (always closed)
    Aquarite chlorinator
    1 waterfall valve
    Phantom cleaner w/ booster
    Think thats it. Won't need to have automation on the drains. So, that'd leave 2 skimmers, the spa and the waterfall, although the first skimmer valve, when closed, will close the second one as well (to operate spa directly).
    Would this be a somewhat easy task to migrate to? I'm using a plain 2 output timer w/ freeze protection for the pumps and cleaner. I'd need 3 valve controllers, the logic control box and then rewire for it, correct? That would eliminate the aquarite box as well. Along with that, I could incorporate a wireless controller to go with it? That would be super sweet.
    Thanks.
    My Pool - 18x24 fully setup Cabana, 22x48 gunite/quartz plaster (3-5-3 depth) & 8' spa w/ spill and 5' natural rock waterfall; Hayward DE filter/pumps/heater; Hayward Pro Logic controller; Phantom cleaner. Finished 06/01/07.
    RedishConstruction.com
    Carrollton, TX
    126
    I have a similsr set-up and went for the Aqualogic PS-8. That gave me extra relays that I can use in the future for landscape lighting or whatever. The PS-4 might not be enough for your application.
    And yes, it will eliminate the SWG box and integrate the SWG into the control box and on board keypad and remote keypad if you go with one for inside the house. Very happy with it.
    Mine doesn't control the skimmer valves; I just leave them wide open.
    7000 gallon IG freeform w/ 6 ft. spa, 21 ft weeping wall, Hayward SP4020NS Northstar pump, Colorlogic LED’s, DE6020 filter and H400IDL2 400,000btu heater. Aqua logic 8 zone controller with Aqua Rite salt chlorine generator, Stonescapes pebble finish – Aqua Blue and flagstone coping, stamped/stained concrete deck
    Guest
    Similar setup and I have the PS-8 and wish I had gone with the PS-16 now that everything is installed and I have lived with it a few years. I could use two more valve actuators (PS-8 only controls 4 and I've used them for pool and spa intake and returns, cleaner, and 1 water feature) since I want to add solar would be nice to control the other water feature by remote.) I do have one relay left. The others are used controlling my equipment--1 speed pump, heatpump, pool light, spa light, fiber optics light, fiber optics color wheel, spa blower, and water features/cleaner pump.
    I have two wireless remotes, one floating one for the spa and a wireless tabletop remote that controls everything. They now have a new wireless remote, the AquaPod, that has an LCD screen.
    Don't think you really need to automate the skimmer valve. It's not going to be changed much except, perhaps, when vacuuming.
    Jul 2007
    North of Dallas
    207
    your right on the skimmer valves now that I think about it. The extra relays would be nice at some point I imagine. Right now the pool lights are on the wall of the cabana, normal light switch, as is the air pump for the spa, so those would need to be rewired I guess. It would be trick tho to have it all done up.
    Thanks for the help.
    Scott
    Jul 2007
    North of Dallas
    207
    last question.
    the PS8 is what I'm going to go with. Do I need a special wireless deal to go with it or does the PS8 automatically support the wireless remotes, like the table top remote and the waterproof one?
    mas985's Avatar
    Pleasanton, CA
    11,742
    On mine, there was a separate wireless kit for the controller. It basically adds the radio and antenna to the side of the controller box. You can add that at any point.
    Mark
    Jul 2007
    North of Dallas
    207
    Quote Originally Posted by mas985
    I actually just ordered the ProLogic off the '08 product line. The ProLogic and AquaLogic are virtually the same except the 'Pro' version is setup internally to work with the new Hayward 'Sense & Dispense' product that maintains chl and ph levels automatically.
    I ordered the ProLogic PS8, the wireless base and 4 valve actuators. Next month, I'll probably follow up with one of the waterproof remotes and the auto ph adjuster.
    The sales dept was worthless tho, couldn't tell me squat about differences of products. Ended up on the tech help line to find out what I needed to know. Once I had my questions answered, I knew which one I needed and what route to take. I'll say I'm glad I made that call though or I would've ended up with the wrong thing and be ******.
    Jul 2007
    North of Dallas
    207
    screw it. just ordered the ph adjuster and remote.... might as well get it here so I complete the install all at once and can try it out upon installation.
    Jul 2007
    North of Dallas
    207
    The ProLogic PS8 just got here. Hopefully I can start getting it installed this weekend. The PH adjuster won't be here for another week as it hasn't hit the shelves yet and is a spcl. order item at this point.
    Guest
    Let us know how it works when you get it all hooked up.
