Results 1 to 8 of 8
Thread: Return jet pressure
    Aug 2008
    Delaware
    45
    Return jet pressure
    Hello,
    I just recently changed the sand in my filter after 5 years using the same sand(New pool) because I was having problems clearing up the green water upon opening.
    So..... I have noticed a trikle of water on occasion coming from the top of the filter....beneath the band clamp.
    The reason I am writing.....since changing the sand I have noticed a drop in the flow coming into the pool via the jets,should I be concerned ??
    My new pressure gauge runs between 8-12
    Thanks for all your help
    Suzi
    Susi
    30X14 IG,Vinyl,13,800 Gal
    Hayward-Pro Series Sand filter(Rated flow75GPM/284LPM)
    SWG-Aqua Comfort,Polaris360 Auto Vac
    22,551
    Re: Return jet pressure
    Did you lube the gasket good when putting the filter back together? If not you probably should take it back apart and clean and lube it well prior to reassembling it.
    What did the gauge read before?
    Aug 2008
    Delaware
    45
    No I did not,What kind of lube should I use?
    My pressure was usually 12-16 before
    Susi
    22,551
    Silicon pool lube.
    Aug 2008
    Delaware
    45
    Thanks
    What do you make of my decrease in pressure?
    Susi
    22,551
    Have you changed anything else except the sand?
    Do you see bubbles in the pump basket?
    With a lower pressure you're either moving more water or your pump is not pumping as much as before.
    Aug 2008
    Delaware
    45
    No other changes
    new pump last year
    No bubbles in the pump basket
    Could a poor seal at the gasket
    cause lower pressure?
    Susi
    22,551
    It certainly could but you'd probably see bubbles.
