Results 1 to 17 of 17
Thread: 2 Speed pump recomendation
    Apr 2012
    South Dakota
    87
    Can anyone recommend a good 2 speed pump to upgrade to? Electricity rates in my state are fairly low so I don't know if I would benefit much with a variable pump.
    Would it be worth it just replacing the motor with a 2 speed? Found some 2 speed motors that would be a direct bolt on for a few hundred dollars.
    18600 Gallon In Ground
    Vinyl liner
    Aqua Genie Skimmer/Return
    Purex Triton Challenger wet end with Emerson 2EZ Speed Two-Speed with Timer Motor 3/4HP #EB2980T
    Sta-Rite 145361 Cristal-Flo II High-Rate Sand Filter 22Inch
    Taylor K-2006
    22,550
    Re: 2 Speed pump recomendation
    If the wet end is in good shape it's a very good idea to just replace the motor with a 2-speed.
    Apr 2012
    South Dakota
    87
    It doesn't make any odd noises and the pro I had open the pool said it sounds fine. Figure if I don't have to cut into the plumbing I could just replace it myself.
    Is 3/4HP enough for my pool size? I run it about 10-12 hours and it seems like it does a good job.
    Vinyl liner
    Taylor K-2006
    38,301
    If you put a motor that is smaller than your current motor, you also should replace the impeller.
    What pump and motor size do you have now?
    Just realized that info may be in your signature which I can not see on my phone.
    Posted with Tapatalk ... sorry if I sound short ... hate typing on phone
    Apr 2012
    South Dakota
    87
    Purex Triton Challenger 3/4 pump
    Vinyl liner
    Taylor K-2006
    22,550
    A 3/4 hp is a good size for your pool as long as you don't have any water features that require more flow (which apparently you don't). You may have to go with a 1 hp 2-speed but if you do it'll be fine with the 3/4 hp impeller. If you wanted a little more flow you could change the impeller too but then you're getting into the cost of a new pump.
    bobodaclown's Avatar
    Apr 2011
    Murrieta, CA
    2,360
    I found this motor earlier this season.
    2EZ Speed - .75HP Square Flange 2 Speed with Timer
    https://www.americanbestpoolsupply.com/detail/13495.htm
    http://www.americanbestpoolsupply.com/s ... /0/2ez.htm
    They come in square flange and C-flange.
    Hope that helps.
    Apr 2012
    South Dakota
    87
    bobodaclown- That looks like a good motor with a timer at a good price.
    Vinyl liner
    Taylor K-2006
    I have put in dozens of those motors, they are great. The wiring is a little different though so read the instructions
    Apr 2012
    South Dakota
    87
    Quote Originally Posted by keene3b07
    Thanks. That does give me more confidence to order one next week.
    Vinyl liner
    Taylor K-2006
    Apr 2012
    South Dakota
    87
    Vinyl liner
    Taylor K-2006
    Apr 2012
    South Dakota
    87
    Anyone?
    Vinyl liner
    Taylor K-2006
    22,550
    Yes, that motor will replace your existing motor.
    Apr 2012
    South Dakota
    87
    Installed the motor yesterday with some new gaskets and this morning the electricians provided a 230V line and it works like a champ. Thanks to everyone that offered their opinion.
    I did go with the US Motors / Emerson 3/4HP 2 speed programmable. I thought it was very easy to swap out the old motor.
    I will have to see if the factory default settings on the timer are going to be adequate to keep the pool properly clean.
    Vinyl liner
    Taylor K-2006
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    That was a good price! Nice job on the fix
    Jul 2013
    Central FL
    12
    Would you say this is a much more reliable motor (2EZ Speed) than the imPower variable speed motor by Marathon Electric? I want to replace the single speed motor in my Pentair WhisperFlo 1hp pump with either a dual speed or v.s. motor like the imPower, but since that's a relatively new motor technology (permanent magnets and totally enclosed motor) I'm wondering if they'll hold up quite well to central FL's weather. Would really appreciate your help and recommendation.
    10k gal. plaster IGP with attached Spa, Pentair EasyTouch 4 automation system with 4 circuit wireless control, Pentair WhisperFlo WF-24 1hp single speed pump, Pentair IntelliChlor IC20 Salt Water Chlorine Generator, 3x Savi Melody w/color LED's, Pentair MasterTemp 400 LP water heater, Pentair Clean & Clear CC150 Cartridge Filter.
    Apr 2011
    Murrieta, CA
    2,360
    Stew, glad it worked out for you.
