Results 1 to 12 of 12
Thread: shock question
    shock question
    Hi, i read the "shock your pool" in pool school, but i'm still not understand all. For example my CYA is 40 and then my shock level will be 16, so i need to keep adding chlorine at 16 ppm and until my water is clean and CC less than 0.5. My question is before I put the shock to my pool, do i need to add FC to 16? or if any number (like 10, 12) is fine? Because the overnight test will perform on morning and the best time shoocking is at night. It will lose some FC during the morning and afternoon.
    Also I bought the Hth super shock N swim shock, it is 1 lbs per 12000 water. If my pool is 27000 gallons, if i OK to use 3 lbs? or i need to use 2.25 lbs only? If i use more shock, did it damage my pool? My pool is vinyl liner.
    - NY Albany ~27000 water
    - In ground Vinyl 18' X 40' X 8' Deep Curved Roman End
    - Pentiar TA 60 Sand Filter
    - Pentair WhisperFlo 1HP Energy Efficient Full-Rated 2-Speed
    - 250K BTU Nat/Elec. Heater
    Smykowski's Avatar
    Sep 2011
    3,065
    Re: shock question
    Aim for a 16ppm target, a little higher is ok, a lot lower is not. Keep adding bleach as often as it takes to keep your FC at 16. For the first day, you may have to do this every hour, but as you kill the organics in your pool, the FC will hold longer, and you can test less often.
    coffeegoddss's Avatar
    May 2012
    Minooka, IL
    93
    Re: shock question
    Why not just use bleach to shock the pool? Bagged "shock" has a lot of extra stuff in it and is waaaay more expensive. Shocking with bleach is a lot more hauling jugs back and forth but it's a lot cheaper in the long run.
    AG, 10,400 gallons, filter cartridge, 2HP pump
    Coffeegoddss...bonafide thread killer!
    POOL SCHOOL...fortheloveofgawd, read POOL SCHOOL
    Smykowski's Avatar
    Sep 2011
    3,065
    Re: shock question
    Quote Originally Posted by coffeegoddss
    ^^^This^^^
    Sorry, I read the question about FC levels, and I completely missed the part about the powder. I have the same philosophy about my pool. If it needs something, I add that chemical, and I don't want to have to factor in byproducts.
    Re: shock question
    How to shock your pool to use bleach? The bleach or liquid chlorine will hold the chlorine, but Bagged "shock" just temporary chlorine and will gone later. Did i understand correctly?
    May 2012
    Minooka, IL
    93
    Re: shock question
    All chlorine is temporary. The sun and contaminates in the water will constantly consume it. Shocking is a process and can take days or even weeks. You have to add chlorine constantly throughout the process depending on how fast its being consumed. Bagge "shock" products have a lot of additives that can cause problems down the road - number one being CYA. Its just easier AND cheaper to raise and keep your FC at shock levels using regular bleach.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,037
    Re: shock question
    Quote Originally Posted by kwing01
    Chlorine by itself is a gas. A dangerous gas. So it has to be combined with something else to make it manageable. Bleach is NaOCl, when it breaks down it leaves behind salt. The various powdered forms will leave behind either CYA - stabilizer - or Calcium, Either one of those will cause problems when they build up over time. There's nothing wrong with using those powders if you are low on CYA or CH. But it's simpler and safer to add what you need individually so you have better control over what goes in your pool. That means liquid bleach. Also called liquid chlorine, sometimes even liquid shock!
    38,369
    Re: shock question
    No they both contain the same chlorine, but the powders also add either CYA or CH both of which are bad at high levels.
    Liquid chlorine (bleach ) only adds chlorine and is generally cheaper.
    Review some of the articles in Pool School if you do not understand this.
    Posted with Tapatalk ... sorry if I sound short ... hate typing on phone
    Re: shock question
    Sorry if i understand correctly, it mean i only use bleach (liquid chlorine) to keep my pool to my shock level until my water is clean and CC less than 0.5. This is shock right? so i don't need another item "bagged shock" to do another shock?
    Richard320's Avatar
    Jan 2010
    19,037
    Re: shock question
    Yes, that is shocking and no, you don't need anything else.
    Sep 2009
    Greentown, IN
    914
    Re: shock question
    Chlorine is chlorine, it just comes in different strengths and when packaged as a pool additive, usually w/ added by products such as CYA or calcium.
    Stores sell "shock" products that many believe they can just dump in the pool once to solve their problems.. Not true. It's a process, not a product. Companies are makin lots of money on people's confusion.
    Unless you are runnin a SWG, you don't want any more CYA in your pool. You didn't tell us your CH levels, so don' know if any additional calcium would be a problem for you.
    Bagged "shock" is chlorine yes, but again w/additions u don't likely want or need in your pool... And it is much more expensive than liquid chlorine/bleach. When you buy bleach/chlorine make sure you get the plain old stuff without fragrance, etc and check for it's strength. At the grocery and hardware store it is usually 6%, at the pool store ask for liquid chlorine and it will be the same thing at 12%.
    After you have you chlorine, plug the strength into the pool calculator to find out how much you need to add to get you at or just above shock level. You will need to check your FC levels often an keep your level maintained until your 1) water is clear 2) your CC is .5 or less 3) and you pass the overnight FC test. It may take awhile, but once you've passed those tests you shouldn't have any further cloudiness or trouble unless your FC gets too low.
    Indiana, ABG 24'x52" Galveston by Blue Cascade (Craigslist buy w/part of deck included), 13,500 gallons, Intex SWG, solar panels mix 2, TF-100 test kit.
    Test kits compared
    Purchase test kits
    Re: shock question
    Thanks, now i'm understand it.
