Results 1 to 18 of 18
Thread: nitpicky fas-dpd test question
    My pool hazed up slightly last night after a pool party, so I assumed that similar to another recent post, I had an increased biologic load in the pool, from the extra swimmers. I added 2 extra ppm last night to the usual dose of Cl, and the water looks better this morning. I can't even tell if the water has any haze left or not. That's easier to tell when it's sunny.
    My question is this: I can't seem to get a consistent number when I use the fas-dpd test.
    For example, last night I got:
    7.0, 0
    6.5, .5
    7.5, 0
    I added 5ppm Cl after testing
    This morning, results were:
    10.5, .5<cc<1.0(took 2 drops to clear)
    11.0, .5
    I try to be very precise when I run the test. I follow the extended directions to the letter. The only thing that is hard to keep the same from test to test is that sometimes I end up using a scoop of powder that seems to be all powder, sometimes there are a lot more "chunks" in it. (I warned you this question was nitpicky! )
    I can't decide from all these results if I need to go through the shock process or not.
    (This was not a true oclt since it was already fairly light outside when I tested this morning)
    Btw the swg in my signature is not turned on right now.
    30000 gallon inground gunite pool
    Intelliflo ic-60 SWG, pentair tagelus sand filter, 1.5 hp whisperflo pump, tf 100 test kit,
    2 kids(tl), 1 mini-dachshund/lab mix(t),
    Central Illinois
    coffeegoddss's Avatar
    May 2012
    Minooka, IL
    93
    Re: nitpicky fas-dpd test question
    I got tripped up by the description of a "heaping scoop". I wish there was a picture to go along with the directions so I knew exactly how heaping. I started using the alternate "two level scoops" just to be more consistent.
    AG, 10,400 gallons, filter cartridge, 2HP pump
    Coffeegoddss...bonafide thread killer!
    POOL SCHOOL...fortheloveofgawd, read POOL SCHOOL
    Jul 2011
    Indianapolis
    63
    I use two scoops as well; I don't remember who said it but I read on here last summer that too little powder is a problem, but too much is not. So I go for a touch more rather than a touch less.
    19000 gallon IG installed in 2003, owned by me since 2010, vinyl liner, 18x36, Sta-Rite PLM-150 cartridge filter, 1hp AOSmith motor on <brand unknown> pump, automatic cover, BBB since August 2011
    Yes, I've read that too: a little too much, within reason, is fine.
    What I can't seem to figure out is why I'm getting slightly different results when I do multiple tests on the same sample. Normally I don't run more than one test, but if I'm doing an oclt or trying to see exactly how much Cl the pool is using, the accuracy starts to matter.
    I'm sure the inconsistency is with me, since I am fully on board with this being the best Cl test.
    Thanks for the input.
    Central Illinois
    Could it be static causing the drops to be different sizes? Maybe slightly different sample sizes?
    If I were trying to check less than 1 ppm change with my K-2006 then I would use the 25mL sample. Maybe this would give you a more accurate reading.
    Kayak Pool - 12 ft. x 24 ft. rectangular, 5˝ ft. deep end
    Frog System, Sta-Rite-Modular Media Cartridge Filter, Pentair 1 H.P. pump
    AquaPRO Pro500 heat pump & Automatic AutoGuard™ Pool safety cover
    harleysilo's Avatar
    Mar 2012
    North Georgia
    1,924
    The chunks vs. powder thing bothers me as does the "heaping spoonful"........I just heap up the spoon with chunks or powder and assume all is well.....but i don't do the test more than once on the same sample but you can be assured I WILL now and see if i have issues replicating results.
    I also would like to know why one is supposed to wipe with a wet cloth the tip of the purple stuff????
    18'x43' Sport Pool
    19,000 Gallons Vinyl Liner 3'-3.5'-4'
    SWCG and D.E. Filter
    Test Kits - Pool Calculator - Chlorine/CYA Chart - Pool School
    Secret Weapon for Pool Chemistry Testing
    R-0870 powder is the indicator dye that causes the pink color in the FAS-DPD test. You need to add enough to bind to all of the chlorine in the sample. Technically, the higher your TC level, the more R-0870 powder you need. In practice, two level tiny spoons, or one "heaping" tiny spoon generally does it. However if your TC level is very high you may need more. Using too little R-0870 will give you false low results. Using too much won't have any effect (unless you use a really huge amount). Generally if you need quite a bit more R-0870 the sample will turn pink for a moment and then go brown or clear. If that happens you certainly need more R-0870. However, it is possible to add just a little too little and not notice and get an incorrect result. To avoid problems it is simplest to always add a bit too much R-0870 just to be safe.
    If the R-0870 gets too clumped it won't dissolve properly. It always clumps a little, more over time. Generally this isn't an issue, but if it gets really clumped you can just crush the clumps back into powder.
    Variations in test results can come from many sources. First, make sure to fill the test vial to the same level each time. A 1 ml difference in initial filling will cause a 10% error, often noticeable. Second, hold the dropper bottle vertically and squeeze gently so that the drops appear to fall off the tip "naturally" under their own weight, instead of being "sprayed" out of the bottle. That gets the most consistent drop size.
    Wiping the tip of the dropper bottle with a damp tissue helps prevent static electric buildup on the tip. If a charge does build up on the tip it can cause the drops to be smaller than usual. This is normally not an issue, and when it does come up it is usually only on the TA test. However, it is possible for this to affect any of the tests where you are counting drops.
    Thank you all
    Central Illinois
    harleysilo's Avatar
    Mar 2012
    North Georgia
    1,924
    Dang now I'll have to start wiping the tips! Thanks for the explanation! Might need to pick up an old school mortar and pestle for the powder!
    18'x43' Sport Pool
    May 2009
    Austin, Texas
    77
    I'm frankly frustrated by the ambiguity of these instructions, and I don't think the original poster is being "nitpicky" at all. What does "if your TC level is very high" (how high?), "you *may* need more" (how much more?), "simplest to always add a bit too much" (how much is "a bit"?) really mean?
    I'm also getting very inconsistent results for trying to measure whether or not I'm losing only 1ppm of FC overnight--it all depends on which measurement I count, and I'm trying to be consistent. With this much ambiguity how can I really know when I'm done shocking? Please help me understand how this is really "trouble free"? It sure doesn't feel like it. :|
    Mike
    25k IG w/ Pebble Sheen +8' diameter spa w/spillway w/ Hayward ProLogic +T-CELL-15 SWCG
    Cartridge Filter and Gas Heater on Hayward Pump SPX3215X20Z1PE (w/ 2.00 HP, 1.10 SF motor)
    +separate waterfall on Hayward Pump SPX3210Z1PE (w/ 1.00 HP, 1.25 SF motor)
    Mar 2007
    San Rafael, CA USA
    12,082
    The reason to use more DPD powder when the FC is very high is if you add powder and you see a flash of pink and it disappears -- that's how you'll know it's too high. You add more powder until you get a distinguishable color (i.e. not so faint a pink that you wonder if it's there at all). You don't have to add enough powder to react with all the chlorine because the FAS-DPD drops will be reacting with the chlorine so by the time you get to where it goes from pink to clear there is very little chlorine left no matter how much you started with. The only effect on measurement error with how many scoops you use is in how much of a transition you see from pink to clear so is the error in that last drop.
    If the FC level is very high such that adding powder shows a flash of pink but goes clear, then if you add more powder so you get a consistent pink then adding FAS-DPD drops during the test will first have the color intensity increase as the FC gets used up by the FAS-DPD and the dye becomes less bleached out. As you continue to add FAS-DPD, the color intensity will then decrease and you'll get to the pink-to-clear transition at the end of the test. See this link for technical details about the test and in particular Figure 2.1 that shows how chlorine reacts with the dye to produce a colored product and a colorless product where at high oxidizer levels there is more of the latter product (i.e. the bleaching out effect). When you add FAS-DPD drops, this reaction is reversed (goes to the left) as shown in Figure 2.3.
    If you are wanting more precision than 0.5 ppm, then use a 25 ml sample size where each FAS-DPD drop represents 0.2 ppm. For normal chlorine testing you typically don't need this sort of precision.
    As for being trouble-free, that will only happen if you realize that the criteria are rough rules-of-thumb and not absolute cutoff points where magically the quality of the pool goes from being horrid losing 1.2 ppm FC overnight to absolutely pristine when losing 0.8 ppm FC overnight.
    I don't know if I'm on the right track, but if I add a pretty hefty scoop of powder (with little if any clumps in it) that my results are much more consistent than I had been getting when I first posted. I may have been using just a little too small an amount of powder, as one of the moderators had suggested. So I feel more comfortable with my results now. I hope that helps other posters in this thread.
    As always, I appreciate all the help I get here, especially since as far as I know there are no other BBB'ers in my area, my pool builder gave me zero and I mean zero guidance when it comes to water chemistry, and the local pool store folks think I'm nuts (since I won't purchase any of their magic pool chems and just use liquid chlorine)
    Central Illinois
    Apr 2012
    Wichita Ks
    29
    If you do a search on youtube of "taylor fas-dpd test" you will find a video demonstrating the test. I found it helpful from the standpoint that One could see they did what looked like 2 heaping scoops to me.
    I too was all over the place when testing with it and found i became consistent when i began using the speedstir. for the fas test, that thing is the best.
    23k Vinyl, Sand Filter tr60, 1hp Whisperflo pump,Coverstar autocover
    Polaris 280,K2006 kit,direct sunlight
    May 2009
    Austin, Texas
    77
    Quote Originally Posted by chem geek
    This is the first I've heard of the 25 ml sample size option. Are there any other instructions for using this option? How much of the powder is recommended with this amount? 2.5 heaping spoonfuls?
    Mike
    Mar 2007
    San Rafael, CA USA
    12,082
    See Extended Test Kit Directions. You still use 2 scoops of DPD powder.
    Aug 2010
    Dallas, TX
    4,052
    In a pool, performing the 25ml test is a waste of reagent.
    I didn't think that was nitpicky at all. I had the same question in my mind for a while.
    I watched the YouTube and Low and behold... I am using the WRONG END of the scooper.
    I am using about the same amount of powder as the video shows,so I am not concerned. It is nice to know how I SHOULD be using the scooper so I know for sure I am using the right amount. The TF-100 Kit only has you adding 1 heaping scoop, not 2.
    Thanks for being nitpicky!
    13600 gal A/G Vinyl, Sand Filter, 1.0 HP Single Speed Pump, 'Lil Shark Cleaner, Full Sun 99% of the day, No trees, etc anywhere in sight.
    Happily BBB-ing since 2009!!! Still learning ;-)
    30,419
    The exact amount you use is not important. If the solution turns pink, you have used enough.
