Thread: Pentair sand filters
    I am looking at a 27-30k gal free form pool. One PB states the TR-100 is the one the other states the TR-140 is.
    Pentairs literature shows TR 100 capable of 98gpm flow and 24 hr turnover is 140,000 gal. This seems more than adequate? Doesn't it?
    Blaine
    50' x 22' 27k gal shotcrete freeform, 2hp 2 sp Pentair Whisperflo, Pool Pilot RC-52 SWCG, Pentair TR 100 sand filter, Prowler 820 robot, Florida Sunseeker LED lights.
    My pool build:
    osage-hills-pool-build-t50526.html
    Re: Pentair sand filters
    They will both work, but you will be happier with the larger filter. Larger filters are slightly more efficient and can go longer between backwashing/cleaning.
    30,419
    More important than the pool size, be sure to matchthe pump size to the filter. a Full Srvice 1hp pump would be a very good match for the TR100.
    What about a 2 speed pump, would you still recommend 1 hp? Of course, the PBs are recommending 2 hp...
    Blaine
    My pool build:
    Thought i would give additional info to help with pump sizing. Pool size is roughly 50x22. Will have three 2in suction outlets (2 skimmers, 1 drain) and 5 or 6 returns. I would like two 2 in return loops. Longest run to pad would be 80-90 feet, pool and pad at same level. Only water features would be 2 bubblers on a tanning ledge. Will have booster pump for pressure cleaner or use robot.
    Blaine
    My pool build:
    22,548
    If you're running all the inlets and outlets separately back to the pad a 1½ hp pump would be a good fit. I'd also go with the larger filter. Given the bubblers I'd consider running two pumps. One for the main system and one for the bubblers. Either that or go with a variable speed pump. The beauty of a VS pump is that you can adjust the flow to whatever you desire it to be and get the bubblers exactly like you want them.
