Thread: Plant life coming up through liner
    Jul 2007
    Michigan,
    18
    Would you believe today when I was trying out some new goggles I happen to notice 3 pieces of plant life coming up through the liner, they are now clear in color due to my shocking of the pool when I opened it. 2 of the little plants are next to the seam at the junction of the wall and the floor,the other is in about 15 inches from the edge.
    It is leaking but they appear to be slow leaks as far as I'm aware of.
    How do I fix these leaks without draining my water.
    Will try and post some pics when I get them.
    14500 gl, oval, vinyl
    Sep 2009
    Greentown, IN
    914
    Re: Plant life coming up through liner
    Wow... something I fear.
    I would guess you would need to do your best to remove as much of the plant as you can without harming your liner any further and then apply a patch. I would venture to guess that due to your shocking the pool that the plants themselves are dead and shouldn't be a further problem after that.
    Indiana, ABG 24'x52" Galveston by Blue Cascade (Craigslist buy w/part of deck included), 13,500 gallons, Intex SWG, solar panels mix 2, TF-100 test kit.
    Test kits compared
    Purchase test kits
    Nov 2010
    Calera, Al
    271
    That looks like nutsedge. I am sorry to say, I have a feeling you may be finding more... The best nutsedge killer I have found is image herbicide. It should have been applied to the ground prior to putting up the pool...
    17,000 gal, IG Gunite Diamond Brite plaster Kidneybean,w/7x11 tanning ledge& 3x5 swimout bench,244T 300lb Hayward Pro high rate sand filter(63 GPM) , Hayward 1Hp Super Pump w/3/4 hp booster pump, Polaris 280, Laars Lite 2 175k N/G Heater, Tf-100, Speed stir
    Jul 2007
    Michigan,
    18
    could this be the culprit it seems to grow all over the place, and if so how do I remedy the situation
    Thanks for all the help
    Regards David
    22,537
    Injecting Image herbicide under the edge of the pool is probably about all you can do until you replace the liner. If you get a good soaking around the pool you may be able to fend it off. Patching the holes as rather easy. Just pull the grass out and apply a patch over the hole.
    cramar's Avatar
    Nov 2010
    Sault Ontario
    1,143
    Long term fix may require emptying the pool, spray the area, new liner with gorilla pad. I believe gorilla pad stops nut grass.
