Thread: Just want to stop by say hello
    Whats up people,
    My name is D, or Zaltzy, I live in MA, just got as home that has a pool, and personally I have never had one, so i am hoping you guys can help me out when I need it. Just want to say thank you up front! Thank you!
    Sep 2009
    Greentown, IN
    914
    Re: Just want to stop by say hello
    Welcome!
    If you haven't started yet, take a look at Pool School and order yourself one of the recommended test kits. That's a wonderful place to start, and you will be glad you did!
    Indiana, ABG 24'x52" Galveston by Blue Cascade (Craigslist buy w/part of deck included), 13,500 gallons, Intex SWG, solar panels mix 2, TF-100 test kit.
    Test kits compared
    Purchase test kits
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Welcome to tfp, zaltzy
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    Welcome aboard, zaltzy
    In addition to the previous posts, I would recommend becoming familiar with the PoolCalculator. This will take the guesswork out of figuring out the proper chemical dosage for each of the tests listed. Also, the items in the leftmost column (e.g., FC, pH, TA, CH, etc.) are hyperlinks that you can click on to read more about that item and why you need to test for it.
    Butterfly's Avatar
    South Carolina
    10,045
    Welcome to the forum
    You're done SLAMing when:
    Feb 2008
    Denton, TX
    5,061
    Welcome to TFP!
