Thread: HELP! Some weird pump activity
    Jun 2012
    Edmond, OK
    69
    Trying to fight my algae problem. Dosing with bleach all day yesterday. Everything worked all day while I was working on the pool. I have some air bubbles that I will have to address....
    Woke up this morning and my waterfall was not going. Head out to the pump and the basket is empty. Shut the pump down and start looking over things. I did not find anything obviously wrong so I started it back up. It took about a minute to get primed and pumping, but it only stayed pumping for about 30 seconds. It was like someone just shut the water off. Three feed lines, drain and two skimmers.
    I have it working now, though it is not pumping to full capacity. I have the drain feed open and my floor vacuum head connected to the deep end skimmer. If I turn the shallow skimmer valve on, it pumps for a bit and then quits drawing water.
    Any ideas? I'm stumped.
    15,000 Gallon IG
    StaRite System 3 Cartridge Filter with new cartridges!
    Pentair Whisperflo 1 1/2 HP Pump
    RayPak RP2100 Digital Heater
    And, most importantly, the TF-100 test kit!
    I'm not saying let's go kill all the stupid people...I'm just saying let's remove all the warning labels and let the problem sort itself out.
    Re: HELP! Some weird pump activity
    That usually indicates an air leak somewhere on the suction side of the plumbing. The most obvious possibility is that the pump strainer basket lid is not sealing correctly, but really the air leak could be anywhere.
    Jun 2012
    Edmond, OK
    69
    Thanks Jason. I've got pumping again. It's not completely right as I still have some air bubbles, but at least it's pumping.
    15,000 Gallon IG
