Thread: Pentair platinum psi side pool cleaner not moving?
    Sep 2011
    Montgomery Texas
    89
    Hey guys everything going great with my new pool but..... Now the pool cleaner is not moving. I checked the booster pump its on. I also disconnected the side hose fitting and the screen is clear. Also no water movement in the hole where the fitting attaches. I'm thinking a clog. Any other ideas?
    Thanks Steve
    24X38'ish 23,500 gallon Geometric with 10x10 spa(12jets), Pentair IC40 SWG, Pentair intelliflow(pool-spa), pentair whispersflow 2HP(booster spa jets), Two Polaris 1.5 Hp blowers, Pentair Wisperflow XF 3HP(2 6 foot water falls), Pentair clean&clear plus 520, Pentair Master temp 400. Intelli PH acid dispenser, Intellitouch with iPhone and iPad control. Two 45000 BTU fire bowls and one 60000 BTU fire pit.
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    Re: Pentair platinum psi side pool cleaner not moving?
    Hm, that's strange since you said the booster is on. A clog is possible, but that seems unlikely given that the booster is after the filter (right?). Is there any valve that could be turned the wrong way?
    Sep 2011
    Montgomery Texas
    89
    Sorry for the late reply. I thought it was cavitating a little due to how loud the pump was. So with that in mind I turned my pool pump up to max rpm and sure enough it primed and started moving normally. I also noticed a small leak at the front of the pump where the PVC attached at the front of the pump. I Resealed it at I haven't had and problems so far. Tanks for the reply. Steve
