Thread: dolphin Diagnoistic?
    I have an older Dolphin Diagnostic that has not worked for a couple of years. When it died there were some surges in the power, I cant bring myself to just throw it away without messing with it some more. It tried to work the last time I played with it, does anyone know what the the voltage should be at each wire from the power supply to the unit?
    20 x 40 Vinyl, w/ Pentair 1 hp pump & Hayward 24" top mount filter
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Re: dolphin Diagnoistic?
    I am not sure on the pinout, but I have seen specs on the power supply saying 24VDC (30VDC Max)
