Results 1 to 11 of 11
Thread: Does anybody have a document to track test results?
    Jul 2011
    East Providence, RI
    17
    Hi Folks,
    I love the site and have learned a ton since discovering it last fall. I've gotten myself a proper TF-100 test kit and I'm wondering if anybody has made a document to capture their daily/weekly test results?
    I thought it might be useful when trying to identify problems. If none exists I may need to make one and post it
    38,000 gallon In-Ground, gunite bottom/fiberglass wall (older style I've not seen elsewhere)
    Sand Filter, Hayward 1HP SuperFlow 2 (not sure flow rate)
    Built @1980
    Mar 2010
    Spring, TX
    1,082
    Re: Does anybody have a document to track test results?
    Quote Originally Posted by PJD
    Hi Folks,
    There is a spreadsheet someone made one time and posted. I tried to find it, but cant sorry.
    13,000 Plaster IG Pool approx
    Hayward C5030 Cart Filter
    Emerson 1081 EB653 1.0 HP 1.40 S.F. 3450 RPM
    Pool Calculator, Pool School, TF Test Kits
    RaviePoolGirl's Avatar
    Nov 2011
    Napa, CA
    47
    20,000 gal inground hourglass shape with 7' Hot Tub with overflow; Gunite
    Hayward TriStar 1.85/.22 THP - Hayward cartrige filter- SWG.
    Hayward Gas Heater
    Jul 2011
    East Providence, RI
    17
    Thanks!!!
    I didn't use the search...classic noob
    EDIT: to add that thread was great. As a noob I'd suggest stickying some of that stuff or cross-referencing it in the Pool School.
    Built @1980
    Hi Folks,
    I would add, that I use a google spreadsheet. That way I can just post the link to it so others can look at it.
    docs.google.com
    17,800 gallon, IG pool, 595 sq feet (17x35x4.5 avg rectangle), Hayward 525 cartridge filter, diamondbrite, 2 hp 2 speed hayward tristar filter, Stenner 45mhp10 automatically chlorinating
    Oct 2010
    michigan
    284
    anyone have a webpage of one, then could easily hit the print button
    15,000 gallon inground fiberglass pool with spa. 350lb Sand filter, 1.5 hp pump, and heater
    East_Akl_Neil's Avatar
    Apr 2012
    Auckland, New Zealand
    70
    Im currently in the process of modifying one of the ones in the link above that gives a recommendation of what to do, if anything and gives a place to log what you did. Just need to sort the pH out and it should be all go. Trouble is for most on here, it's in metric, but shouldent take to much to convert.
    Late 1970's 39000L IG Concrete Pool with Vinyl Liner
    Austral FT55 Sand filter
    Hurlcon E170 Pump Brochure,Manual
    32-40mm Pipe work
    Living in beautiful New Zealand
    stev32k's Avatar
    Mar 2009
    Mobile, Alabama
    492
    Here is a simple excel spreadsheet I made for tracking test results and chemical additions. You are welcome to download and use it if you like.
    P.S. the spreadsheet is setup to print on 8-1/2" X 11" in landscape mode. You could also save the results electronically by date.
    Attached Files Attached Files
    20' x 40' IG with vinyl liner volume approx. 35,000 gal.1.5 H.P. main pump, Polaris 280 cleaner W/ 3/4 H.P. booster pump
    Hayward sand filter, 3.14 sq ft, 62 gpm. Stenner 45 MPH10 chlorine feed pump. 1 micron final filter bags (home made and very effective)
    poolmama67's Avatar
    May 2012
    Arkansas
    209
    I don't have excel. Any suggestions?
    24 ft. round ABG-vinyl-15200 gallon
    Sand Filter w/1 1/2 HP pump
    Installed May 2011
    Taylor K-2006 test kit
    BBB method
    http://www.poolcalculator.com/
    pool-school/chlorine_cya_chart_shock
    pool-school/shocking_your_pool
    pool-school/pool_test_kit_comparison
    Nov 2011
    Napa, CA
    47
    Stev - I like your spreadsheet. Thanks for sharing.
    Hayward Gas Heater
    stev32k's Avatar
    Mar 2009
    Mobile, Alabama
    492
    Quote Originally Posted by poolmama67
    You can download open office for free. It has a spreadsheet that is compatible with excel. http://www.openoffice.org/
