Thread: how long should chlorine last in closed covered pool?
    I closed pool in October. When opened at the end of May I had 1-2ppm of chlorine. Is that normal? CYA 30-40. Don't know how much chlorine I had in the pool when it was closed, probably between 2-5. Pool closing kit with chlorine free shock was used right before the cover was put on.
    Thanks
    Bill
    18'X4' 7600 Gal AG
    3/4 HP Pentair Pump
    Hayward S166T 100 lb sand filter
    Re: how long should chlorine last in closed covered pool?
    Chlorine can last quite a while in a covered pool, though all winter is rare. If you topped up the water level before testing the chlorine could have come from the fill water.
