Thread: In ground pop ups won't turn
    I'm at wits end. In ground shasta pool with popups that won't turn. Popups come up zones change however some zones never go down so therefore they don't turn. Additionally some popups won't seat all the way down therefore they don't turn. Removed the manifold there are no broken glue in valves and all the gears are fine no broken teeth or anything. Can someone please help me troubleshoot what is going on? BTW pressure is perfect at 30 psi.
    22,553
    Re: In ground pop ups won't turn
    Have you pulled the heads out and checked them? I'd suspect the problem is with the heads.
    I've pulled every head and inspected them when the pump is off the heads will go down and turn. It has to be something with the manifold
    22,553
    It sounds like the seals in the selector are leaking by not allowing the heads to operate properly.
    How do I seal them?
