Page 1 of 2 12 LastLast
Results 1 to 20 of 22
Thread: Making bulk 12.5%+ more manageable?
    Mar 2008
    Wake Forest, NC
    128
    Ok so I like Dave but my 12.5 bleach in bulk in 5 gallon containers. Over the years I have saved a few 1.5 and 1 gallon bottles to make the process a little bit more manageable. Needless to say I am growing tired of my transfer method. I siphon over a full hour 10 gallons into assorted bottles. I know I could get a bigger hose to speed it up but I don't want it to become too fast that I spill during transfer. Give me some other ideas in how to get the bleach to the bottles. I have searched for manual pumps and I can't seem to find any I like for 5 gallon containers. [attachment=0:g4rb8392]ImageUploadedByTapatalk1339285665.294757.jpg[/attachment:g4rb8392]
    IG Vinyl liner, 21,500G sport bottom, TR-60 sand filter, 3/4 HP Whisper Flow, BBB with 12.5% Liquid Chlorine
    30,432
    Re: Making bulk 12.5%+ more manageable?
    You can get a screw-on lid with a spigot on it for about three bucks (from alanda) replace your current lid with that lid and then turn the carboy on it's side and use the spigot to fill your smaller containers...easy peasy.
    Mar 2008
    Wake Forest, NC
    128
    I want yell at him next time I am in there. I have asked him numerous times for something like that. Always says no......
    Instead of using the smaller bottles, siphon out of the larger bottles directly into the pool as needed.
    When using the larger jugs (2.5 gallons and up), I use a length of Polyethylene tubing (about 3/8 to 1/2 inch ID) to siphon the bleach out of the jug into the water. Available at most hardware stores by the foot.
    1) Fill the tubing with water by submerging the tubing under water and put your finger over one end.
    2) Put the other end in the jug.
    3) Put the end with your finger under water and remove your finger.
    4) When the correct amount of bleach has been dispensed, pull the tubing out of the liquid chlorine to allow the tubing to clear.
    5) Rinse the tubing in the pool water so that no bleach is left in the tubing.
    Warning: Do not suck on the tubing to get the siphon started.
    Example
    post296021.html
    Support the site
    bibeaud's Avatar
    Aug 2011
    P'Burg NJ
    73
    Get a chlorine carboy pump from Beckson. http://www.becksonindustrial.com/poolpump.html
    I just purchased one. I put a small outdoor table next to my Liquidator and attached a 1/2" id tube that transfers the liquid chlorine from the 5gal carboy directly into the Liquidator black funnel. I used it tonight for the first time.
    Before this I used a spigot screwed into a 70mm carboy cap.
    11,000 Gal Trilogy "Utopia" Fiberglass Pool, 1HP Jandy Pump, Jandy CS200 Cartridge Filter, Raypak 199k BTU Heater, Liquidator, CMP Off-Line Chlorinator. Cleaners: Polaris 360, Blue Diamond, Poolvernuegen Pressure
    Mar 2008
    Wake Forest, NC
    128
    Quote Originally Posted by bibeaud
    THAT is exactly what I am looking for. Bonus below it, cap wrench! I guess I just call them to order?
    Quote Originally Posted by JamesW
    Now that just sucks the fun out of everything!
    Wonder which one is worse from a medical standpoint...
    Chlorine or gasoline.
    I'll guess gasoline. I'll have to ask the boss when she wakes up.
    Gasoline definitely has a unique taste that lingers for quite some time!
    Rob B
    My $100 pool finally died after 6 years.
    Totally got our monies worth!
    Butterfly made me do it...
    Jun 2007
    New Jersey
    653
    I've done gasoline (when young and drunk and stupid and car tanks could still be siphoned) and survived. I'd do it again before I'd try Cl. But you burp hi-test for a long time.
    Current: 28,000G 18'x36' I/G AnthonySylvan Plaster; Waterway 60 sq.ft. DE Filter; 1.0hp x 1.65 SF Two-Speed (B2982) WhisperFlo; 2004-Present
    Previous: 40,000G 20'x40' I/G Koven unlined WWII salvage 5/8" marine steel; Lomart Stainless Sand Filter; 3/4hp Hayward SuperPump; 1946-2003 (managed by me from about 1964)
    Ancient Taylor K-2000, upgraded with Taylor CH, TA, and FAS-DPD, and TFT CYA tests.
    If u pu tit in a standard 5 gal bucket u could use a pump like this. I use mine 4 hydralic fluid ofcourse but i dont c why u coulnt pump bleach with it
    http://compare.ebay.com/like/3006086691 ... si=y&cbt=y
    do you do the transfer at night? I think 12.5% is pretty sensitive and letting it sit out in the sun like that could really decrease the cl levels in it.
    I use a stenner pump with a partially buried 15 gallon tank. I would love to be able to top it off 5 gallons at a time.
    17,800 gallon, IG pool, 595 sq feet (17x35x4.5 avg rectangle), Hayward 525 cartridge filter, diamondbrite, 2 hp 2 speed hayward tristar filter, Stenner 45mhp10 automatically chlorinating
    Mar 2008
    Wake Forest, NC
    128
    Typically I do it in the evening when the sun is low on the horizon not in the blazing daylight sun.
    I am really not too concerned with the degradation that may happen during this period. The supplier I get this from stores a large pallet container of it on his dock during the day to facilitate delivery to a trailer or vehicle that pulls up with carboy's or larger containers on trailers. It sits in the sun all day, Even then when I get it it is hot! Hot as in more than 12.5%. I have no idea how hot but i have had it burn me slightly. Not something I do regularly. I think 6% is like drinking water compared to this stuff. I leave it sit over the winter and it is still really strong after 6 months in the garage.
    Sep 2011
    Omaha, NE
    95
    Where are people buying bulk chlorine from? I can not find a place around me that has at least 5-Gal carboys, nor the higher concentrations. So far, I am stuck hauling 96oz jugs to the backyard....
    16X24 Oval Doughboy
    10,000 Gallons~
    Pentair Dynamo .75/1.0 HP pump
    16" Pooline D-400 Sand Filter w/ 6-way valve
    Mar 2008
    Wake Forest, NC
    128
    Power washer supply house is an option. That is were I get mine.
    Administrator Leebo's Avatar
    Jul 2011
    Eastern Ohio
    7,110
    Bibeaud.....
    Do you need to call that company to order the pump or am I missing how to order online? We found a local place that sells 12.5 in 5 gallon carboys for $13. Not bad in my mind.
    bibeaud's Avatar
    Aug 2011
    P'Burg NJ
    73
    You have to call them during the week.
    May 2011
    Southern NH
    18
    Hi Dave - sorry for the ignorance, but what/who is alanda? I've spent a while googl'ing, but everything I've found are wholesale sites with minimum orders/exorbitant shipping, etc. I'm in NH and would love to get my hands on a couple of these (just converted my neighbor to a BBB'er) for short money (tired of dealing with siphioning, etc).
    24000 Vinyl. Hayward: DE Pro-Grid 3620, 1 HP SP2607X10
    250k H250FDP Propane Heater
    Booster pump 6060 w/ Viio Turbo Cleaner
    bibeaud's Avatar
    Aug 2011
    P'Burg NJ
    73
    Carboy spigots can be bought from Utah Biodiesel Supply at http://utahbiodieselsupply.com/carboys.php
    Buy the cap and the spigot.
    May 2011
    Southern NH
    18
    Awesome site - thanks! I called around to about 6 different local pool stores before I found the spigot/cap - pricier than the website you pointed out (spigot and cap was $9), but much better than the $25 for the beckson pump (plus freight which I didn't even ask how much that would be).
    May 2011
    Southern NH
    18
    So now I understand why people would spend the money on a pump. The spigot is nice/no spills, but slowwww...(pour a little, big slow glurp, repeat). Makes perfect sense now that I've seen it in action. Takes a while to fill up 5 gallon bottles... Too bad I can't pop air holes in the refillable carboys.
    I'll be asking santa for a pump this year
  20. Back To Top    #20
    nhguy,
    I'm in Manchester. Where did you end up finding that spigot/cap?
    Wick
