Results 1 to 7 of 7
Thread: Second rerturn in my AGP
    I am thinking about putting a second return in my AGP. The main return is within about ten inches of the skimmer, and in my opionion does a poor job circulating the water on the bottom. My thought was since I have a extra return fitting, I would mount it six or eight inches off the bottom of the pool to help stir the dust and debris off the bottom. Also I think this would help maintain a more even temp. throughtout the whole pool. Any thoughts on this?
    24' Sharkline Venture AGP
    1.5HP Hayward Pump and Sand Filter
    Waveglow Jet Thru-wall LED Light
    Re: Second rerturn in my AGP
    More useful than a second return is a return that can be aimed to point down and to the side.
    My main return can be pointed down but when it is pointed down it creates a "water tornado" and makes an annoying sucking sound so i keep the return pointed slightly upward to keep a tornado from forming.
    Nov 2011
    Moberly,MO
    1,010
    Don't know where you are located but if you winterize your pool that bottom return will be a major hassle.
    Over 30 years in the pool business
    We build vinyl, fiberglass, stainless steel pools
    Certified in Hydraulics
    How does it work when you point it as far to the side as it will go (either side) and just slightly downwards.
    i have played with moving the eye every which way and still get a small tornado almost everytime. I'm located in Indiana, so good point swimcmp, I didn't think about wintertime. Hard to think about snow when it's over 90 degrees today. lol
    Mar 2008
    Wake Forest, NC
    128
    If it is a threaded eye for the return just go to home depot and get two threaded 90's and two threaded straights an a length of pipe and just fabricate a return that is lower inside the pool
    IG Vinyl liner, 21,500G sport bottom, TR-60 sand filter, 3/4 HP Whisper Flow, BBB with 12.5% Liquid Chlorine
