Thread: bbb method is awesome
    Apr 2012
    SW Ohio
    456
    i just did a test on my water in my intex 18x 52 in deep pool below are the readings
    fc=3
    tc=3
    cc=0
    ph=7.2
    ta=60
    cya=below 30, still i can see the dot even with the tester full
    i just added 2 lbs of stabilizer in a sock yesterday and last night in front of the return jet so i imagine it is not getting a good reading on it yet, i heard on here somewhere it can take up to a week to show up on a test.
    water is crystal clear and 76 degrees
    i know there is some cya in the pool because it has held 3 ppm of cl for the last 24 hours with bright sunlight during the day.
    am i doing this right ?
    18x52 intex ultra frame pool 6981 gallons, 1 HP LL pump with 19 in sand filter,BBB method,borax 50ppm
    leslies DPD test kit + fas-dpd chlorine test kit + borates test strips
    thru wall skimmer,hard plumbed with 2 returns 1 1/2 sch 40 pvc
    1 large fountain 1 inch sch 40 pvc,shut off ball valves on all
    Butterfly's Avatar
    South Carolina
    10,045
    Re: bbb method is awesome
    Yep, you're doing it right and the pool looks fabulous
    Once that CYA is dissolved, maintain the FC levels based on the amount of CYA you have added to the pool - even tho it can take up to a week to show on test (as you know).
    I suggest that you add some baking soda and get the TA from 60 to about 80.
    You're done SLAMing when:
    Sep 2009
    Greentown, IN
    914
    Looks like you're on the right track!
    Welcome
    Indiana, ABG 24'x52" Galveston by Blue Cascade (Craigslist buy w/part of deck included), 13,500 gallons, Intex SWG, solar panels mix 2, TF-100 test kit.
    Test kits compared
    Purchase test kits
    hawkeye's Avatar
    davenport,iowa
    118
    Good show mate.....
    18ft 52in deep doughboy 8000 gallons
    22 in sand filter
    1 1/2 pump
    tk-2006 test kit that rocks!
    12.5% chlorine
    aqua critter vac
