Results 1 to 16 of 16
Thread: Pool calculator Android app
    Jun 2010
    Rural Southern Illinois
    49
    I was wondering about the pool calculator app for Android, or another app. Is the calculator app worth it? I downloaded a free app called pool pal, but the amount of bleach varies between it's calculations and that of poolcalculator.com. Does anyone have any experience with this app or another similar? Thanks for your help!
    17100 gallon 27' Round 4' Deep Above Ground Pool
    Hayward Cartridge Filter 1 HP pump 50 GPM flow rate
    Re: Pool calculator Android app
    A number of people on the forum recommend Simple Pool for Android devices.
    Articfox918's Avatar
    May 2012
    Western, Wisconsin
    99
    Yes an android app would be most appreciated for us non apple people then that would complete my rooted desire running CM
    POOL SIZE: 27 FT round 52" Deep on edges 66" Deep in center
    FILTER TYPE: Hayward Sand Filter
    PUMP SIZE: Hayward 1 HP Pump 60GPM
    FILTER SIZE/FLOW RATE: Unknown
    HEATER: None at the moment but in process of making my solar panels should be operational by next season!
    May 2012
    Western, Wisconsin
    99
    I cant seem to find this Simple Pool in the market is it/or was it only a beta version?
    is it possible we may someday see the pool calculator on android? That would be sweet then my pool care would be 100% mobile as I have my spreadsheets and graphs all on my phone just need a pool calculator app and I don't need to fire up my laptop. However I can use my browser to access the calculator, but an app would be sweet!
    Jun 2012
    Lafayette, Ca / USA
    260
    +1 - could also use a recommended one, or better yet the PoolCalculator ported to Mobile.
    30,000 Gal FIBER GLASS (over Gunite Plaster) Pool, Dolphin Nautilus PLUS Robot, (2) Cartridge Filter System (old), 1/2 HP Pump, Full Sun, Solar Heated, TF-100 Test Kit.
    kenmar's Avatar
    Apr 2009
    Schnecksville, PA
    288
    Search the Android market for simplepool... One word.
    20'x40' / 30,000 Gal / In Ground / Vinyl
    Pentair FNS 48 DE Filter / Pentair Challenger 1.5 HP Pump
    Jandy Lite2 400k BTU Propane Heater / Dolphin Dynamic cleaning robot
    TF-100 Test Kit / BBB
    Creator of SimplePool (BBB Friendly Android App) http://www.simplepool.net
    May 2012
    Western, Wisconsin
    99
    Quote Originally Posted by kenmar
    Yup found it now dang playstore entered as one word and BAM! there it is going to check this out now
    Thanks
    +1 for the poolcalculator android app
    But I'll check out simplepool for the time being
    5K gal (16' round), vinyl UltraFrame AGP, stock cartridge intex filter/pump
    using(learning) TF-100 test kit with BBB method
    Jun 2010
    49
    Yeah, that simplepool is a pretty good alternative. I've noticed a couple inconsistencies between it and the pool calculator.
    Whatrymes's Avatar
    May 2011
    E. Bridgewater, MA
    132
    My big problem with "Simplepool" is the options for making adjustments. The one I need to deal with most--chlorine--has no option for 12.5% bleach which I use exclusively, so it is no use to me at the moment. That is the best priced bleach in my part of the world, $2.99 a gallon.
    15 X 30 X 3.6 Ester williams AGP
    10,800 gallons
    Haywood EC40C90 DE filter 1 HP pump
    TF-100 Test Kit
    kenmar's Avatar
    Apr 2009
    Schnecksville, PA
    288
    The option for 10% and 12.5% chlorine will be in the next release... which is coming out tomorrow.
    May 2012
    Western, Wisconsin
    99
    I emailed the dev. They are fixing and adding the 12.5 option which i also use exclusively it is suppose to be in the nexy update which they are working on as i am told
    May 2012
    Western, Wisconsin
    99
    New update is out im downloading now will report back soon
    cwuffman's Avatar
    Jun 2012
    The Woodlands, TX
    66
    I don't mean to detract from the specialized Android apps, but you can access the normal Pool Calculator on your android phone using a web browser. Works just like normal.
    Carl
    29,000 gal rectangular Pebble Sheen in ground pool with raised spillover spa,3hp Pentair variable speed pump, Polaris 280 cleaner with booster pump, Pentair 520 cartridge filter, Pentair Master Temp 400 heater, Stenner 45MPHP10 Peristaltic Pump, TF-100 Test Kit & Speedstir
    May 2012
    Western, Wisconsin
    99
    Quote Originally Posted by cwuffman
    Carl
    Yeah this is what i have been doing since simplepool didnt have tge 12.5% option for chlorine this mornings update fir simplepool has added the 12.5% option. I prefer an app as it eliminates the pinch and zoom effect via browser abd works still if you donf have wifi or network signal. The simplepool app is ok but i think im staying with the poolcalculator as there are some slight inconsistancies between the two.
    Whatrymes's Avatar
    May 2011
    E. Bridgewater, MA
    132
    Well they fixed that issue. I got the update yesterday, good going.
    10,800 gallons
    TF-100 Test Kit
