Results 1 to 9 of 9
Thread: OK if CYA is below 30?
    Jun 2011
    Ridgefield, CT
    73
    My CYA has declined below 30 over the past week or so. I thought I was around 35 last weekend, but I guess the rain and filter cleaning took its toll. Anyway, I seem to have no problem holding chlorine, even on sunny days. Is there a need for me to boost the CYA to 30? I understand that I may have to do some guesstimating in terms of recommended FC levels, although I tend to shoot for the high end of the range. And if I had to shock, I could overshoot a little and assume a CYA of 30. I know recommended levels are 30-50, but if I can maintain chlorine in sunlight, why not go a little lower?
    33,000 gallon plaster pool
    Jandy L-Series -CL580 Cartridge Filter
    Mar 2010
    Spring, TX
    1,082
    Re: OK if CYA is below 30?
    I would say if you are able to maintain your FC leve with that CYA level leave it alone. Less cholorine additions you will have to do. But keep an eye on the CYA level since it is at the bottom of the recommended level fro non SWG pools
    13,000 Plaster IG Pool approx
    Hayward C5030 Cart Filter
    Emerson 1081 EB653 1.0 HP 1.40 S.F. 3450 RPM
    Pool Calculator, Pool School, TF Test Kits
    Isaac-1's Avatar
    SW Louisiana
    6,711
    There is no technical problem with CYA levels all the way down to the bottom of the ability to read it on a test (20 or 30 depending on the view tube) as long as you can maintain FC levels with sunlight in your location. I assume your pool is mostly shaded.
    Jun 2011
    Ridgefield, CT
    73
    Quote Originally Posted by Isaac-1
    Actually, I get a lot of sunlight. The weather has been on and off over the past week, with rain almost daily, but also a fair amount of sunshine. Yesterday, was almost entirely sunny at the pool, with one intermittent shower for 45 minutes.
    Oct 2010
    michigan
    284
    so how much chlorine are you losing daily? or should i say, how much chlorine are you adding on a daily bases?
    15,000 gallon inground fiberglass pool with spa. 350lb Sand filter, 1.5 hp pump, and heater
    Jun 2011
    Ridgefield, CT
    73
    Quote Originally Posted by smooth2222
    When I was starting around 16-17, I was finishing around 11-12, which I thought was quite good for the amount of sunlight and considering I was starting so high. Yesterday, I started around 17.5 and finished at 14. Today, I was still at 12 at noon, and I hadn't added any chlorine yesterday or today.
    To answer your question, I was adding about 2 large jugs of Chlorox over the course of a day, which boosts my FC by almost exactly 5.
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    The CYA in my pool is currently 28. I am intentionally erring on the side of running a bit low on my CYA. Even with a CYA of 28 in the full Texas sun, my FC drops from 4 to 2. Even at an FC level 2, I am in range for my CYA according to the Pool Calculator. I add an average of 96 oz per day of 6% bleach to bump the FC level to 4 after sunset. I have also run several OCLTthis season and have lost zero FC overnight at this CYA level.
    If your CYA is less than 30, I'm curious as to why you are running a chlorine level in the mid teens. This seems like overkill. Per the Pool Calculator, the target FC is between 2 and 6 for a CYA level of 30. You could save a lot of bleach my maintaining the FC at this level. Just to be safe, I would perform an OCLT to rule out any nascent algae or other organic contamination. If you pass the OCLT, then I would maintain an FC of between 2 and 6.
    Jun 2011
    Ridgefield, CT
    73
    Quote Originally Posted by BoDarville
    I was shocking and treating the pool as if my CYA was 30, since that was around what I tested last weekend. I was trying to pass the OCLT and clear out the alagae that we had when we opened the pool. I only passed the OCLT on Thursday night. I will now run at a lower level.
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    OK, now that makes sense. Sounds like you are on the right track
