Results 1 to 12 of 12
Thread: Equipment layout pictures wanted
    May 2012
    Tempe, AZ
    21
    Please publish equipment layout.
    I am stragling to do efficient layout for s simple pool. No fountains. I woul dlike option for solar.
    I also plan on using sand filter (I do not want maintenance of other types), backwashing into a bag filter and feeding it back to the pool. Where I should have check valves? How to avoidn draining the pump during basket cleaout. Agonizing about piping the multiport valve. I read it has 6 positions - but how many ports does it have and where are they and what for?
    Pictures pictures pictures please.
    Pools size: 21,690 gallons in ground plaster on concrete;
    in-line Pentair tablet chlorinator; Triton II with ClearPro sand filter;
    Hayward Ecostar SP3400 vsp; automatic accid injection by SOLAXX.
    Re: Equipment layout pictures wanted
    Take a breath, it's ok. The multiport valve is just a valve that sits on top (or side) of the sand filter. There's only three pipes coming out of the filter, in, out, and waste. The various positions of the valve move water inside the filter in different directions. Back wash, rinse, bypass, etc. has nothing to do with how many puppies (edit-don't you love autocorrect? Puppies = pipes) you need to attach. I'll go out and snap a picture of mine for you right now.
    Rob B
    My $100 pool finally died after 6 years.
    Totally got our monies worth!
    Butterfly made me do it...
    Here's the multiport valve, let me see if I can remember all the positions. Filter, waste, recirculate, back wash, rinse,winter, and closed. (yay me!) These positions just dictate the way the water moves internally in the filter. Not all multi port valves have all these positions.
    As far as the rest of your questions, some one will be along momentarily. I do not have solar and other things to be able to answer them.
    The two hoses on the left, one comes from the pump, the other goes to the pool. The blue hose on the right is waste. I've never heard of running waste water through a bag and back into the pool. Can't imagine that's a good idea, but I'll defer to someone else.
    Rob B
    Oh, and welcome to TFP! It's awesome here.
    Rob B
    Sep 2008
    Melbourne, FL
    141
    Here's my layout ... download/file.php?id=15972&mode=view Best of luck with yours!
    Karl
    Freeform 15x31 Pool w/ oversized spa, 1 1/2 HP Blower, Pentair Quad 60 DE Filter, Heliocol solar panels, Pentair Maxitherm 400K BTU heater, Pentair IC40 SWG, Pentair Easytouch 4 w/wireless remote, Pentair IntelliFlow VSP, and Pentair Intellibrite LED Pool/Spa lights.
    One more thing, we're going to have to know what kind of pool, how big, what pump, etc. to answer these questions.
    To stop the pump from draining, and I'm assuming you have an above ground, I just put my filter in the closed position, then take the hose off of the pump that's coming from the skimmer and quickly bend it back up into the top of the skimmerto stop that from pouring out of the pool. You can also put valves on the skimmer. If you're hard piping the pool, valves are a must. If it's an in ground pool, I do believe you need valves too, but I'll also defer that to other people.
    Rob B
    May 2012
    Tempe, AZ
    21
    Quote Originally Posted by Kias
    To stop the pump from draining, and I'm assuming you have an above ground, I just put my filter in the closed position, then take the hose off of the pump that's coming from the skimmer and quickly bend it back up into the top of the skimmer to stop that from pouring out of the pool. You can also put valves on the skimmer. If you're hard piping the pool, valves are a must. If it's an in ground pool, I do believe you need valves too, but I'll also defer that too other people.
    Sent from my Galaxy Nexus
    I have 22,100 gal in ground pool. I am planning on Hayward EcoStar pump, I have Triton II TR60 Clear Pro (gravel, sand, zeo,sand) (I know TR100 would be better). I am re-piping above and below ground from 1.5" to 2" and doing sweeps instead of elbows. Added separate 2" suction line for Baracuda.
    The backwash into a bag filter and back into the pool should work as the bag filter works as good as sand (it just has lesser capacity), but it should save me on water and chemistry bills.
    This looks like a good simple layout with an automated solar option!
    Rob B
    Ok, I think that diagram is a good start, some one will be along to help you with the barracuda line, and to smack me into submission if I'm wrong about anything so far.
    Rob B
    ...or everyone is out swimming.
    Rob B
    There are some great plumbing diagrams on this page.
    This was how I laid mine out. I struggled to find decent pics on the internet. I too have the multi-valve. Directly to the left of the multi-valve I installed a backwash pipe that leads to a drain. I keep the basket from emptying by shutting the one valve going into the heater and the skimmer line. The bypass is already closed. The water in the lines have nowhere to go. I have put unions in front of each piece of equipment so I can disconnect it and take it in the house at end of the season. I don't leaving anything out. It laterally takes 15 minutes to disconnect the gas, electric, and all the equipment (pump,heater,chlorinator, & piping). The multi-port valve stays connected to the heater that is stored in heated garage. I built a small table that I set over top of the heater and stack the filter on top of. The pump is drained and stored in basement.
    It does take about a half hour to reinstall everything but, It's worth it.
    Someone once said "No man drowns if he perseveres in praying to God, and can swim."
    16 x 34 w/Lasko walkout step
    Hayward Super 2 1-1/2hp. Pump
    Hayward DE 4820 Filter
    Hayward Low NOx 200 Heater
    Hayward Color Logic 4.0 Light
    White PVC Coated Step & Hand Rails
    McEwen Malcom 27-mil Liner
    Rainbow Chlorination Feeder (EMPTY AND NEVER TO SEE A 3" Tri-chlor TABLET AGAIN!)
    Klipsch Sound System
