Thread: Exterior Backfill, Back fill, question
    Ok, search gave a lot of back fill info for inside of pool, (I think). I want to be sure before I begin the labor on our new pool...
    Installer said use the earth removed from leveling the area. My plan was to sift dirt to be used against outside pool materials and back fill about 20" on one side down to about 4" above former grade on other side of pool. We had a foam base and foam floor pad installed inside pool under the liner, so sand wash out should not be major concern. I understand to grade away from the pool so run off is taken away from pool base.
    My question: Should I use a plastic liner between EXTERIOR pool wall and earth back fill? Again I want to be sure as other searches seamed to be referring to using plastic on the interior berm usually made of sand.
    By the way, BBB water in pool is great! Removed the Nature2 before it was ever used!
    AGP 12'x24'x54"~7700 gal | Vinyl | Dual Speed Hayward Pump | Cartidge Filter 17psi (new)
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: Exterior Backfill, Back fill, question
    Welcome to tfp, polabear
    Quote Originally Posted by PolaBear
    I think plastic is typically on inside, if used. I am not sure, but I don't think it would hurt anything on the outside wall.
